Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT_AWT bridge: Can I register Swing Events for SWT widgets?
SWT_AWT bridge: Can I register Swing Events for SWT widgets? [message #459388] Mon, 08 August 2005 16:35 Go to next message
Bob is currently offline BobFriend
Member
Hello everybody,
i am using the SWT_AWT bridge to include a graph drawing library in my
Eclipse Plugin.
I want to accompany this graph view with a Properties view, showing
details of the nodes in the Graph, when a node in the Graph gets clicked
onto by the user.
Is this possible?
IŽve only found examples where a swing frame is embedded into SWT but none
of the Examples showed whether itŽs possible to execute code based on
certain events within the Swing widget.
Any answer is appreciated.
Cheers
Bob
Re: SWT_AWT bridge: Can I register Swing Events for SWT widgets? [message #459595 is a reply to message #459388] Thu, 11 August 2005 22:21 Go to previous messageGo to next message
Steve Northover is currently offline Steve NorthoverFriend
Why wouldn't this work (provided you call both SWT and Swing from the
"right" thread using asyncExec() and invokeLater())?
"Bob" <bobruney@gmx.net> wrote in message
news:5a12ecd5d4776d887478c1616bde656b$1@www.eclipse.org...
> Hello everybody,
> Eclipse Plugin.
> onto by the user.
> Is this possible?
> I
Re: SWT_AWT bridge: Can I register Swing Events for SWT widgets? [message #459602 is a reply to message #459388] Fri, 12 August 2005 07:27 Go to previous message
Stefan Langer is currently offline Stefan LangerFriend
In case there is no direct way try using pipes to communicate between
the two threads.
HTH
Stefan
Bob wrote:
> Hello everybody,
> Eclipse Plugin.
> onto by the user.
> Is this possible?
> none of the Examples showed whether itŽs possible to execute code based
> on certain events within the Swing widget.
> Cheers
> Bob
Previous Topic:Select all
Next Topic:Looking for a widget to pick an int
Current Time: Sun Apr 18 22:10:40 GMT 2021
Powered by FUDForum. Page generated in 0.01467 seconds
