Serialization issue [message #453510] |
Tue, 01 August 2006 12:55 |
Originally posted by: amarcus.us.ibm.com
I'm having issues similar to those brought up on 9/28/2004 in the thread
"Classloader / Serialization issue", but the solutions proposed do not
fix it.
I have to plugins, A and B. B has a class Clazz that is internal to
plugin B, but is returned through an interface to methods of plugin A.
When a call from a method in A to a method in B occurs, B deserializes a
Clazz object that it retrieves through HTTP. When this occurs, I get a
ClassNotFoundException for Clazz.
Upon further inspection, I realized that I can create a Clazz object in
plugin A (even though I would never actually do this), and even call
Class.forname("path.to.Clazz"). However, if I call the method in B
which deserializes a Clazz object, the ClassNotFoundException is thrown.
I tried using the buddy system (I am using Eclipse 3.2), but I am either
using it incorrectly or it's not working. Can anyone suggest anything?
Thanks in advance,
Adam Marcus
Re: Serialization issue [message #453515 is a reply to message #453510] |
Tue, 01 August 2006 13:49 |
I've just solved the issue. Sorry to trouble you all. Eclipse Buddy
system solved it:).
-Adam
> fix it.
> Thanks in advance,
> Adam Marcus
FUDForum. Page generated in 0.03110 seconds
