Re: Ecllipse Application Launcher [message #453403 is a reply to message #453364] |
Fri, 28 July 2006 13:02 |
Originally posted by: baldin.gmail.com
Christine,
Try convert you external JAR to Plugin from existing JAR archives, export
packages in this new plugin in runtime tab, and put this plugin in
dependencies tab from you major plugin.
Think that, you never pain with others dependencies !!!
regards,
Davi
"ChrisTina Lewin" <christine.lewin@wincor-nixdorf.ch> escreveu na mensagem
news:eaaj1r$k4h$1@utils.eclipse.org...
> In the main tab there is a field "Bootstrap Entries" where
> you can put additional java classpath entries. They are
> added to the java.class.path.
> My question is:
> If I define a product and export said product I lose these
> entries and my application doesn't run.
> I tried entries in eclipse.ini like
> -Djava.class.path c:\temp or
> -Ddev c:\temp
> it didn't work. The entry was just ignored.
> What is the equivalent to Bootstrap Entries for an
> exported product?
> I've tried so much, read zillions of blogs and web entries,
> but found nothing so far.
> Cheers,
> Christine
FUDForum. Page generated in 0.03199 seconds
