Re: What is best way to set a property outside RCP application for use by the RCP ap [message #453337 is a reply to message #453297] |
Wed, 26 July 2006 14:51 |
Originally posted by: dittmar.steiner.web.de
Bill Blalock schrieb:
> What is the best way to set a property outside of an RCP application for
> use by the RCP application? Eclipse 3.2, Windows XP, Java 1.4.2 is the
> environment.
> In this case I want to specify a folder for the RCP application to use.
> I don't want to hard code it. The RCP user doesn't need to see or
> change it. After the RCP is installed (in a shared install environment)
> the property value will rarely change.
> Can the Preferences class be used in this case? That is, can a
> preference/property which will be accessed by the Preference class be
> set outside of the RCP application? In an .ini file perhaps?
> Is there a way to set it up as an Eclipse preference but set it outside
> of Eclipse?
> AbstractPreferenceInitializer doesn't seem to directly support this.
> One could extend this class, create a Java Property object and read the
> value through it. Is there any better facility built into Eclipse?
> Using an environment variable would work.
> Using System.property doesn't seem advisable.
> Does anyone have any suggestions? I would appreciate a code snippet or
> explanation of how to read the preference/property.
> Thanks all
> BillB
Hi Bill,
the simplest way is to put the value as a VM argument in the config.ini.
This can be done through the dialog input of "sth.product/Launcher/Launching Arguments/VM Arguments".
Also possible is the use of org.eclipse.core.variables valueVariable. (just ignore the use of a initializer class)
This makes it part of the plugin, maintainable through updates and independent of any launcher.
Or put a configuration file in your plugin's class path and use getClass().getResourceAsStream() (which i personally don't like)
regards
Dittmar
Quidquid latine dictum sit, altum sonatur.
- Whatever is said in Latin sounds profound.
Re: What is best way to set a property outside RCP application for use by the RCP ap [message #453405 is a reply to message #453366] |
Fri, 28 July 2006 13:37 |
>>> for use by the RCP application? Eclipse 3.2, Windows XP, Java 1.4.2
>>> is the environment.
>>> use. I don't want to hard code it. The RCP user doesn't need to see
>>> or change it. After the RCP is installed (in a shared install
>>> environment) the property value will rarely change.
>>> outside of Eclipse?
>>> the value through it. Is there any better facility built into Eclipse?
>>> or explanation of how to read the preference/property.
>>> Thanks all
>>> BillB
>> Hi Bill,
>> (just
>> regards
>> Dittmar
> Thank you Dittmar:
> How would the program access the data in this case? A snippet would be
> very helpful.
> Could you explain this or point me to some documentation?
> Again, thanks for your time and help.
Hi Bill,
* sorry, it's NOT the config.ini, it's the <yourproduct>.ini
-vmargs
-Dmy.varialble.name=myValue <- don't for get the D!
-D... <- each arg a new line
String val = System.getProperty("myProperty");
Also accessible through <yourproduct>.product "Launcher/Launching Arguments/VM Arguments" dialog. The ini file will be created
then automatically. Does not work for pure plugins.
* Value Variables (my prefered solution, works for products and plugins):
String val = null;
IValueVariable var = VariablesPlugin.getDefault()
.getStringVariableManager().getValueVariable("my.varialble.name ");
if (var != null)
val = var.getValue();
plugin.xml:
<extension
point="org.eclipse.core.variables.valueVariables">
<variable
description="My Property"
initialValue="myValue"
name="my.varialble.name"/>
</extension>
hope this answeres you questions.
Dittmar
FUDForum. Page generated in 0.04571 seconds
