Home » Eclipse Projects » Rich Client Platform (RCP) » Cannot launch plug-in
Cannot launch plug-in [message #453028] Thu, 20 July 2006 08:21 Go to next message
Patrick Godeau is currently offline Patrick GodeauFriend
Member
I have problems with running a plug-in. For example, following the
"Creating an Eclipse plug-in" cheat sheet from Eclipse 3.2, when I click
the "Launch an Eclipse application" link, I have this error:
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench"
could not be found in the registry. The applications available are:
<here the names of my applications>
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:68)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
In the Run dialog for launch configuration, I can only select a product
or application from my workspace, but there is no
"org.eclipse.ui.ide.workbench" in the list.
Please help, thanks.
Patrick
Re: Cannot launch plug-in [message #453033 is a reply to message #453028] Thu, 20 July 2006 09:35 Go to previous messageGo to next message
Ilya Shinkarenko is currently offline Ilya ShinkarenkoFriend
Member
hi,
Check whether your plug-in set is valid (Run configuration -> Plug-ins
-> Validate plug-in set). Seems that you are missing some plug-ins in
your launch configuration.
Ilya Shinkarenko
www.imedic.de
www.rcp-training.com
Patrick Godeau wrote:
> Hello,
> at
> at
> at
> at
> at
Re: Cannot launch plug-in [message #453048 is a reply to message #453033] Thu, 20 July 2006 14:32 Go to previous message
Member
Ilya Shinkarenko a écrit :
> hi,
I checked plug-in validation, but it says: "No problems were detected in
the selected set of plug-ins".
Other ideas, or should I file a bug report?
Patrick
Previous Topic:Using FileDialog for SaveAs
Next Topic:ProgressBar and SMOOTH
Current Time: Thu Oct 03 23:36:30 GMT 2024
Powered by FUDForum. Page generated in 0.03512 seconds
