Home » Eclipse Projects » Rich Client Platform (RCP) » Contributing about menu?
Contributing about menu? [message #452644] Tue, 11 July 2006 09:35 Go to next message
Hagen Thorbjörn Seifert is currently offline Hagen Thorbjörn SeifertFriend
how can i contribute the "about" menu in a plugin.xml/fragment.xml?
Thanks.
Re: Contributing about menu? [message #452649 is a reply to message #452644] Tue, 11 July 2006 14:40 Go to previous messageGo to next message
Mike Evans is currently offline Mike EvansFriend
On Tue, 11 Jul 2006 11:35:06 +0200, Hagen Seifert wrote:
> Hello,
> Thanks.
See 'About Dialog' in
http://www.eclipse.org/articles/Article-Branding/branding-yo ur-application.html
Mike E.
Re: Contributing about menu? [message #452673 is a reply to message #452649] Wed, 12 July 2006 08:40 Go to previous messageGo to next message
>> Hello,
>> Thanks.
Thank you for your answer. But i don´t want to brand my about dialog, i
want to contribute the "about" entry in the help menu in a
fragment.xml/plugin.xml.
Re: Contributing about menu? [message #452689 is a reply to message #452673] Wed, 12 July 2006 17:52 Go to previous messageGo to next message
On Wed, 12 Jul 2006 10:40:28 +0200, Hagen Seifert wrote:
>>> Hello,
>>> Thanks.
Do you eman put the text in a properties file?
If so set the ABout Dialog text to '%aboutText' and then add the aboutText
values in a .properties file.
If you mean create your own About Dialog I think you need to create your
own Help menu and 'About' action - see RCP tutorial part 3 for an example
( http://www.eclipse.org/articles/Article-RCP-3/tutorial3.html)
Mike E.
Re: Contributing about menu? [message #452836 is a reply to message #452689] Mon, 17 July 2006 15:32 Go to previous message
>>>> Hello,
>>>> Thanks.
Thanks again. I think i have to explain whats the problem is and what i
want to do.
We have a application, which defines the about entry (help menu) by code:
this.aboutAction = ActionFactory.ABOUT.create( window );
this.aboutAction.setText( Messages.getString(
"MainWorkbenchAdvisor.menu.help.about" ) ); //$NON-NLS-1$
register( this.aboutAction );
Now we want to create a second application which is using this "main"
plugin, too. The text of this about menu entry is "About blabla" (blabla
is our app name). This text is defined in a messages.properties. Which
possibility do I have to change this text?
Previous Topic:why are (cvs) "remove from view" settings non-persistent
Next Topic:Automatic build doesn't work(Unable to find
Current Time: Sun Oct 13 21:11:19 GMT 2024
Powered by FUDForum. Page generated in 0.04315 seconds
