Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Multi-line Text with constant number of visible rows...
Multi-line Text with constant number of visible rows... [message #451453] Wed, 02 March 2005 15:53 Go to next message
Originally posted by: msmiths.uk.ibm.com
I am trying to emulate the behaviour that can be achieved in SWING by using
a JTextArea and a JScrollPane together, as follows:
JTextArea payloadWindow = new JTextArea();
payloadWindow.setRows(10);
payloadWindow.setColumns(80);
JScrollPane payloadWindowScrollPane = new JScrollPane();
payloadWindowScrollPane.setViewportView(payloadWindow);
payloadWindowScrollPane.setMinimumSize(new Dimension(400, 400));
However, I cannot find any way to tell a Text control to size itself to a
given number of displayable rows and columns. I have code similar to the
following:
int cols = 80;
int rows = 10;
GC gc = new GC(payloadWindow);
FontMetrics fm = gc.getFontMetrics ();
int width = cols * fm.getAverageCharWidth();
int height = rows * fm.getHeight ();
gc.dispose ();
payloadWindow.setSize(payloadWindow.computeSize(width, height));
The problem with this is that the Text control is initially empty.
Therefore, when I invoke pack() on my dialog, the control gets resized
smaller. Also, if add extra lines of text (>10) and then pack() is invoked
on the dialog, my Text control gets resized larger then 10 rows.
The behaviour that I would like to see is to always have 10 rows by 80
columns, even when the Text control is empty or contains a large amount of
text, and I would like to have scroll bars displayed for the Text control
when they are required, i.e., when more than 10 rows are entered or a line
longer than 80 characters is entered.
Any ideas?
P.S. I have tried to place the Text control inside a ScrolledPane, but
still cannot achieve the desired results.
Re: Multi-line Text with constant number of visible rows... [message #451546 is a reply to message #451453] Wed, 02 March 2005 18:06 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
You probably have a Layout on the shell and this is overriding the result of
payloadWindow.setSize(payloadWindow.computeSize(width, height)); You can
not mix a Layout with calls to setSize() or setBounds() - you must choose
one or the other. Below is an example using GridLayout that sets the size
of the Text widget:
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout(new GridLayout(2, false));
Text payloadWindow = new Text(shell, SWT.BORDER | SWT.MULTI
|SWT.V_SCROLL | SWT.H_SCROLL);
gc.dispose ();
int cols = 80;
int rows = 10;
int height = rows * fm.getHeight();
GridData data = new GridData();
data.widthHint = width;
data.heightHint = height;
payloadWindow.setLayoutData(data);
Button b = new Button(shell, SWT.PUSH);
b.setText("Button");
shell.pack();
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
"Martin Smithson" <msmiths@uk.ibm.com> wrote in message
news:d04nif$ed3$1@www.eclipse.org...
> using
> following:
> int cols = 80;
> int rows = 10;
> gc.dispose ();
> invoked
> Any ideas?
Re: Multi-line Text with constant number of visible rows... [message #451624 is a reply to message #451546] Thu, 03 March 2005 15:30 Go to previous message
Veronika,
Many thanks... it now works great. It's not immediately obvious from the
docs that Layouts and setSize() or setBounds() methods are mutually
exclusive.
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:d04vaf$or2$1@www.eclipse.org...
of
> of the Text widget:
> gc.dispose ();
> int cols = 80;
> int rows = 10;
> shell.pack();
> shell.open ();
> display.dispose ();
> > Hi,
> > using
a
the
> > following:
> > int cols = 80;
> > int rows = 10;
> > gc.dispose ();
> > invoked
of
control
line
> > Any ideas?
Previous Topic:Regarding Spinner widget in latest SWT swt-3.1M4-win32
Next Topic:Is there a way to actively "read" keyboard modifier state?
Current Time: Wed Sep 30 22:00:10 GMT 2020
Powered by FUDForum. Page generated in 0.18283 seconds
