Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Weird behaviour of GridLayout
Weird behaviour of GridLayout [message #449990] |
Thu, 03 February 2005 10:58 |
Tobias Klein Messages: 2 Registered: July 2009 |
Junior Member |
Hey folks,
I'm currently testing the capabilities of
org.eclipse.swt.layout.GridLayout. I think I've already reached the
limits of that layout.
First I extended org.eclipse.swt.widgets.Composite to get a Widget with
individual borders.
That's the layout of my extended Composite:
| Border-Top |
| | Main-Composite | |
|Border-Left |Border-Right
| Border-Bottom |
Each Border is a Composite with a black Background. These five
Composites are inserted in one "Parent-Composite".
The extended class follows here:
/*********** CODE STARTS HERE **************/
package com.vipco.spe.swtextension;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
* @author tk
* TODO To change the template for this generated type comment go to
* Window - Preferences - Java - Code Style - Code Templates
public class BorderedComposite extends Composite {
private static final int style = SWT.NONE;
private Composite myParent;
private Color myBorderColor;
private int myTopMargin;
private int myBottomMargin;
private int myLeftMargin;
private int myRightMargin;
private int myFillType;
private int myNumColumns;
private GridLayout myLayout;
private GridData myGridData;
private Composite myCenterComposite;
private Composite myTopMarginComposite;
private Composite myBottomMarginComposite;
private Composite myLeftMarginComposite;
private Composite myInnerComposite;
private Composite myRightMarginComposite;
private GridData myCenterGridData;
private GridData myTopGridData;
private GridData myBottomGridData;
private GridData myLeftGridData;
private GridData myRightGridData;
private GridLayout myCenterLayout;
private GridLayout myInnerLayout;
private GridData myInnerGridData;
private Color myInnerColor;
* @param parent
* @param style
public BorderedComposite(Composite parent, Color borderColor, int
topMargin, int bottomMargin,
int leftMargin, int rightMargin, int fillType, int numColumns) {
super(parent, style);
init(parent, borderColor, topMargin, bottomMargin, leftMargin,
rightMargin, fillType, numColumns);
render();
private void init(Composite parent, Color borderColor,
int topMargin, int bottomMargin, int leftMargin, int rightMargin, int
myParent = parent;
myBorderColor = borderColor;
myTopMargin = topMargin;
myBottomMargin = bottomMargin;
myLeftMargin = leftMargin;
myRightMargin = rightMargin;
myFillType = fillType;
myNumColumns = numColumns;
myLayout = new GridLayout();
myGridData = new GridData(fillType);
myTopMarginComposite = new Composite(this, style);
myCenterComposite = new Composite(this,style);
myLeftMarginComposite = new Composite(myCenterComposite, style);
myInnerComposite = new Composite(myCenterComposite, style);
myRightMarginComposite = new Composite(myCenterComposite, style);
myBottomMarginComposite = new Composite(this, style);
myCenterGridData = new GridData(GridData.FILL_BOTH);
myTopGridData = new GridData(GridData.FILL_HORIZONTAL);
myLeftGridData = new GridData(GridData.FILL_VERTICAL);
myInnerGridData = new GridData(GridData.FILL_BOTH);
myRightGridData = new GridData(GridData.FILL_VERTICAL);
myBottomGridData = new GridData(GridData.FILL_HORIZONTAL);
myCenterLayout = new GridLayout();
myInnerLayout = new GridLayout();
myInnerColor = new Color(myParent.getDisplay(), 255, 255, 255);
private void render() {
myLayout.numColumns = 1;
myLayout.horizontalSpacing = 0;
myLayout.verticalSpacing = 0;
myLayout.marginWidth = 0;
myLayout.marginHeight = 0;
setLayout(myLayout);
setLayoutData(myGridData);
myCenterLayout.numColumns = 3;
myCenterLayout.horizontalSpacing = 0;
myCenterLayout.verticalSpacing = 0;
myCenterLayout.marginHeight = 0;
myCenterLayout.marginWidth = 0;
myCenterComposite.setLayout(myCenterLayout);
myCenterComposite.setLayoutData(myCenterGridData);
myInnerLayout.numColumns = myNumColumns;
myInnerLayout.marginWidth = 0;
myInnerLayout.marginHeight = 0;
myInnerLayout.horizontalSpacing = 0;
myInnerLayout.verticalSpacing = 0;
myInnerComposite.setLayout(myInnerLayout);
myLeftGridData.widthHint = myLeftMargin;
myRightGridData.horizontalAlignment = GridData.END;
myTopGridData.heightHint = myTopMargin;
myTopGridData.horizontalSpan = 1;
myBottomGridData.heightHint = myBottomMargin;
myBottomGridData.horizontalSpan = 1;
myRightGridData.widthHint = myRightMargin;
myTopMarginComposite.setLayoutData(myTopGridData);
myLeftMarginComposite.setLayoutData(myLeftGridData);
myInnerComposite.setLayoutData(myInnerGridData);
myRightMarginComposite.setLayoutData(myRightGridData);
myBottomMarginComposite.setLayoutData(myBottomGridData);
myTopMarginComposite.setBackground(myBorderColor);
myLeftMarginComposite.setBackground(myBorderColor);
myInnerComposite.setBackground(myInnerColor);
myRightMarginComposite.setBackground(myBorderColor);
myBottomMarginComposite.setBackground(myBorderColor);
public Composite getInnerComposite() {
return myInnerComposite;
/***************** CODE ENDS HERE ***************/
The first tests of my extended Composite showed a positive result - it
rendered just as I wanted it to be.
But after increasing the depth of nested Composites I've got very weird
results.
See the following Screenshots of several "states" after playing with the
size of the Eclipse window.
http://tklein-home.de/tmp/eclipse_1.jpg
http://tklein-home.de/tmp/eclipse_2.jpg
http://tklein-home.de/tmp/eclipse_3.jpg
Is that a bug in GridLayout??
Test Code follows:
/*************** CODE STARTS HERE ****************/
package com.vipco.spe.editor;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.swt.custom.StyledText;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Group;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IEditorSite;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.part.EditorPart;
import com.vipco.spe.swtextension.BorderedComposite;
public class StructogramEditor extends EditorPart {
private Composite myStaticComposite;
public StructogramEditor() {
* (non-Javadoc)
* @see
org.eclipse.ui.ISaveablePart#doSave(org.eclipse.core.runtime .IProgressMonitor)
public void doSave(IProgressMonitor monitor) {
// TODO Auto-generated method stub
* (non-Javadoc)
* @see org.eclipse.ui.ISaveablePart#doSaveAs()
public void doSaveAs() {
* (non-Javadoc)
* @see org.eclipse.ui.IEditorPart#init(org.eclipse.ui.IEditorSite,
* org.eclipse.ui.IEditorInput)
public void init(IEditorSite site, IEditorInput input)
throws PartInitException {
setSite(site);
setInput(input);
* (non-Javadoc)
* @see org.eclipse.ui.ISaveablePart#isDirty()
public boolean isDirty() {
return false;
* (non-Javadoc)
* @see org.eclipse.ui.ISaveablePart#isSaveAsAllowed()
public boolean isSaveAsAllowed() {
return false;
* (non-Javadoc)
* @see
org.eclipse.ui.IWorkbenchPart#createPartControl(org.eclipse. swt.widgets.Composite)
public void createPartControl(Composite parent) {
GridLayout myParentGrid = new GridLayout();
myParentGrid.numColumns = 2;
myParentGrid.horizontalSpacing = 0;
myParentGrid.verticalSpacing = 0;
myParentGrid.marginHeight = 0;
myParentGrid.marginWidth = 0;
parent.setLayout(myParentGrid);
BorderedComposite myComposite1 = new BorderedComposite(parent, new
Color(parent.getDisplay(), 0, 0, 0),
2, 0, 2, 2, GridData.FILL_BOTH, 1);
BorderedComposite myComposite2 = new BorderedComposite(parent, new
2, 0, 0, 2, GridData.FILL_BOTH, 1);
BorderedComposite myComposite3 = new BorderedComposite(parent, new
2, 2, 2, 2, GridData.FILL_BOTH, 2);
BorderedComposite myComposite4 = new BorderedComposite(parent, new
2, 2, 0, 2, GridData.FILL_BOTH, 2);
BorderedComposite myComposite5 = new
BorderedComposite(myComposite4.getInnerComposite(), new
0, 0, 0, 2, GridData.FILL_BOTH, 1);
BorderedComposite myComposite6 = new
0, 0, 0, 0, GridData.FILL_BOTH, 1);
BorderedComposite myComposite7 = new
2, 0, 0, 2, GridData.FILL_BOTH, 2);
BorderedComposite myComposite8 = new
2, 0, 0, 0, GridData.FILL_BOTH, 1);
BorderedComposite myComposite9 = new
BorderedComposite(myComposite7.getInnerComposite(), new
0, 0, 0, 2, GridData.FILL_BOTH, 2);
BorderedComposite myComposite10 = new
BorderedComposite myComposite11 = new
BorderedComposite(myComposite3.getInnerComposite(), new
BorderedComposite myComposite12 = new
BorderedComposite myComposite15 = new
BorderedComposite(myComposite1.getInnerComposite(), new
0, 2, 0, 0, GridData.FILL_BOTH, 2);
BorderedComposite myComposite16 = new
BorderedComposite myComposite17 = new
BorderedComposite(myComposite15.getInnerComposite(), new
BorderedComposite myComposite18 = new
BorderedComposite myComposite19 = new
BorderedComposite(myComposite18.getInnerComposite(), new
0, 2, 0, 0, GridData.FILL_BOTH, 1);
BorderedComposite myComposite20 = new
0, 0, 0, 0, GridData.FILL_BOTH, 2);
parent.pack();
* (non-Javadoc)
* @see org.eclipse.ui.IWorkbenchPart#setFocus()
public void setFocus() {
Re: Weird behaviour of GridLayout [message #449995 is a reply to message #449990] |
Thu, 03 February 2005 15:42 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
Are you running with Eclipse 3.0?
I ran the following example below on Windows XP with the latest 3.1 Eclipse
build and it worked fine. In 3.1, the GridLayout was reworked and a number
of bugs were fixed. If you are using 3.0, please give 3.1 a try and see if
this fixes your problem.
public static void main (String [] args) {
Display display = new Display ();
Color green = display.getSystemColor(SWT.COLOR_GREEN);
Color red = display.getSystemColor(SWT.COLOR_RED);
Color blue = display.getSystemColor(SWT.COLOR_BLUE);
Color cyan = display.getSystemColor(SWT.COLOR_CYAN);
Shell shell = new Shell (display);
shell.setLayout(new FillLayout());
Composite parent = new Composite(shell, SWT.NONE);
BorderedComposite myComposite1 = new BorderedComposite(parent, green, 2,
BorderedComposite myComposite2 = new BorderedComposite(parent, green, 2,
BorderedComposite myComposite3 = new BorderedComposite(parent, green, 2,
BorderedComposite myComposite4 = new BorderedComposite(parent, green, 2,
BorderedComposite(myComposite4.getInnerComposite(), blue, 0, 0, 0, 2,
BorderedComposite(myComposite4.getInnerComposite(), blue, 0, 0, 0, 0,
BorderedComposite(myComposite4.getInnerComposite(), blue, 2, 0, 0, 2,
BorderedComposite(myComposite4.getInnerComposite(), blue, 2, 0, 0, 0,
BorderedComposite(myComposite7.getInnerComposite(), red, 0, 0, 0, 2,
BorderedComposite(myComposite7.getInnerComposite(), red, 0, 0, 0, 0,
BorderedComposite(myComposite3.getInnerComposite(), cyan, 0, 0, 0, 2,
BorderedComposite(myComposite3.getInnerComposite(), cyan, 0, 0, 0, 0,
BorderedComposite(myComposite1.getInnerComposite(), blue, 0, 2, 0, 0,
BorderedComposite(myComposite1.getInnerComposite(), blue, 0, 0, 0, 0,
BorderedComposite(myComposite15.getInnerComposite(), red, 0, 0, 0, 2,
BorderedComposite(myComposite15.getInnerComposite(), red, 0, 0, 0, 0,
BorderedComposite(myComposite18.getInnerComposite(), cyan, 0, 2, 0, 0,
BorderedComposite(myComposite18.getInnerComposite(), cyan, 0, 0, 0, 0,
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
"Tobias Klein" <tklein_news@online.de> wrote in message
news:ctt05g$t00$1@www.eclipse.org...
> Hey folks,
> org.eclipse.swt.layout.GridLayout. I think I've already reached the limits
> of that layout.
> individual borders.
> | Border-Top |
> | | Main-Composite | |
> | Border-Bottom |
> Each Border is a Composite with a black Background. These five Composites
> * @author tk
> * @param parent
> * @param style
> */ public BorderedComposite(Composite parent, Color borderColor, int
> render();
> myParent = parent;
> myRightGridData = new GridData(GridData.FILL_VERTICAL); myBottomGridData =
> myTopGridData.horizontalSpan = 1; myBottomGridData.heightHint =
> myBottomMargin;
> myBottomGridData.horizontalSpan = 1; myRightGridData.widthHint =
> myRightMargin;
> results.
> Test Code follows:
> * (non-Javadoc)
> * @see
> * (non-Javadoc)
> * (non-Javadoc)
> setSite(site);
> setInput(input);
> * (non-Javadoc)
> return false;
> * (non-Javadoc)
> return false;
> * (non-Javadoc)
> * @see
> parent.pack();
> * (non-Javadoc)
Re: Weird behaviour of GridLayout [message #450013 is a reply to message #449995] |
Fri, 04 February 2005 08:42 |
Junior Member |
Yes I've been using Eclipse 3.0. After reading your message I've also
tested with Eclipse 3.1 (under Win2K). But the problems are nearly the
same. When resizing the Eclipse Window the lines are not further
rendered correctly.
Would it make a difference when I run the code in an independent shell
outside of the Eclipse Workbench?
Please add a few more nested BorderedComposites. When I expanded the
hierarchy of our example with one more nested BorderedComposite I've got
completely strange results. The new Composites hasn't even been shown
anymore.
Thanks for help,
Tobias.
> shell.open ();
> display.dispose ();
Re: Weird behaviour of GridLayout [message #450098 is a reply to message #450013] |
Mon, 07 February 2005 21:35 |
What version of Eclipse 3.1 did you use?
Please enter a bug report against Platform SWT with a modified version of
the code below that shows the problem. Thanks.
news:ctvcjq$k9o$1@www.eclipse.org...
> same. When resizing the Eclipse Window the lines are not further rendered
> correctly.
> anymore.
> Thanks for help,
> Tobias.
>> Eclipse build and it worked fine. In 3.1, the GridLayout was reworked
>> and a number of bugs were fixed. If you are using 3.0, please give 3.1 a
>> try and see if this fixes your problem.
>> shell.open ();
>> display.dispose ();
Current Time: Sat Apr 20 02:43:33 GMT 2024
Powered by FUDForum. Page generated in 0.03157 seconds
