table drawing question.... [message #448176] |
Tue, 04 January 2005 22:26 |
Originally posted by: gopowereclipse.yahoo.com
I have a table where one of the columns is customized. The column contains
the colored and bounded labels as its TableEditors. I'd like to update the
label with different foreground and background color when the row is
selected and de-selected. I registered a SelectionListener on the table. The
SelectionListener alters the foreground and the background color of the
label. When a row is selected, the SelectionListener is notified after the
table is redrawn. I observed the latency between the selection highlight
moving to a different row and the label color changing. It's quite annoying.
You can see the label selection jumpping around. Does anyone know how to
make the drawing smooth in my situation? Thanks a lot for your help.
--Vivian
Re: table drawing question.... [message #448538 is a reply to message #448194] |
Tue, 11 January 2005 19:42 |
Here is the code snippet. The latency is subtle in this snippet. In my real
code, the table is more complicated. It takes longer to get to
updateSelection() method. The delay is observed more frequently. I added a
for loop in method updateSelection() to exaggerate the delay. Thanks!
--Vivian
import java.util.ArrayList;
import java.util.List;
import org.eclipse.jface.viewers.ColumnLayoutData;
import org.eclipse.jface.viewers.ColumnPixelData;
import org.eclipse.jface.viewers.ColumnWeightData;
import org.eclipse.jface.viewers.TableLayout;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.TableEditor;
import org.eclipse.swt.events.FocusEvent;
import org.eclipse.swt.events.FocusListener;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.layout.RowData;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
public class SelectionSnippet
protected Table collectionTable;
protected List sequenceList = new ArrayList();
protected List disposableList = new ArrayList ();
protected int selectionIndex = -1;
static final protected int NUM_COLUMNS = 2;
static final protected ColumnLayoutData[] columnLayouts = {
new ColumnPixelData(30),
new ColumnWeightData(100) };
static final protected int[] columnAlignments = {
SWT.LEFT,
SWT.LEFT };
static final protected String[][] items;
static {
items = new String[30][];
for (int i = 0; i < 30; i++)
items[i] = new String[2];
items[i][0] = new Integer(i).toString();
items[i][1] = "Text " + i;
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new RowLayout());
SelectionSnippet s = new SelectionSnippet();
s.createCollectionTable (shell);
s.populateCollectionTable ();
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
private void createCollectionTable(final Composite parent)
this.collectionTable =
new Table(parent,
SWT.BORDER | SWT.FULL_SELECTION | SWT.H_SCROLL | SWT.V_SCROLL);
this.collectionTable.setLayoutData(new RowData(150, 300));
TableLayout tableLayout = new TableLayout();
this.collectionTable.setLayout(tableLayout);
for (int i = 0; i < NUM_COLUMNS; i++) {
tableLayout.addColumnData(columnLayouts[i]);
TableColumn column = new TableColumn(this.collectionTable,
columnAlignments[i]);
this.collectionTable.addSelectionListener(new SelectionListener() {
public void widgetSelected(SelectionEvent e) {
updateSelection();
refresh();
public void widgetDefaultSelected(SelectionEvent e) {
widgetSelected(e);
this.collectionTable.addFocusListener(new FocusListener() {
public void focusGained(FocusEvent e) {
updateSelection();
public void focusLost(FocusEvent e) {
updateSelection();
protected void populateCollectionTable()
// populate the collection table
for (int i = 0; i < items.length; i++) {
addRow();
this.selectionIndex = 0;
refresh();
protected void addRow()
TableItem item = new TableItem(collectionTable, SWT.NONE);
// set a TableEditor for column 1 to display the Sequence Number
Label label = new Label(collectionTable, SWT.BORDER | SWT.CENTER
| SWT.SHADOW_IN);
label.setBackground(label.getDisplay().getSystemColor(
SWT.COLOR_WIDGET_DARK_SHADOW));
TableEditor editor = new TableEditor(collectionTable);
editor.grabHorizontal = true;
editor.grabVertical = true;
editor.horizontalAlignment = SWT.RIGHT;
editor.minimumWidth = 30;
editor.minimumHeight = collectionTable.getItemHeight();
editor.setEditor(label, item, 0);
sequenceList.add(label);
disposableList.add(editor);
protected void updateSelection()
// added to exaggerate the delay
for (int i = 0; i < 100000000; i++){}
//update the old selection
if (selectionIndex >= 0 && !sequenceList.isEmpty()) {
Label sequenceLabel = (Label) sequenceList.get(selectionIndex);
sequenceLabel.setForeground(sequenceLabel.getDisplay()
.getSystemColor(SWT.COLOR_BLACK));
sequenceLabel.setBackground(sequenceLabel.getDisplay()
.getSystemColor(SWT.COLOR_WIDGET_DARK_SHADOW));
//update the new selection
selectionIndex = this.collectionTable.getSelectionIndex();
if (selectionIndex > -1) {
if (this.collectionTable.isFocusControl()) {
.getSystemColor(SWT.COLOR_WHITE));
.getSystemColor(SWT.COLOR_LIST_SELECTION));
} else {
.getSystemColor(SWT.COLOR_WIDGET_LIGHT_SHADOW));
protected void refresh()
// populate the collection table with the content
TableItem[] tableItems = collectionTable.getItems();
for (int i = 0; tableItems != null && i < tableItems.length; i++)
TableItem tableItem = tableItems[i];
// Column 1: Sequence Number
Label label = (Label) sequenceList.get(i);
label.setText(items[i][0]);
// Column 2: Name
tableItem.setText(1, items[i][1]);
// redraw the underlying widgets
for (int i = 0; i < disposableList.size(); i++)
TableEditor editor = (TableEditor) disposableList.get(i);
editor.layout();
this.collectionTable.redraw();
// update the selection
this.collectionTable.setSelection(selectionIndex);
updateSelection();
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:crgva1$6ia$1@www.eclipse.org...
> Post a small stand alone snippet that shows the problem.
> "Vivian" <gopowereclipse@yahoo.com> wrote in message
> news:crf565$k28$1@www.eclipse.org...
contains
the
> The
the
> annoying.
> > --Vivian
Re: table drawing question.... [message #448635 is a reply to message #448538] |
Wed, 12 January 2005 16:32 |
Steve Northover Messages: 1636 Registered: July 2009 |
This is a bug/feature is in Windows. When you select an item, Windows can't
tell whether you are starting a drag and drop operating or selecting. If
you release the mouse button or move the mouse slightly, then it figures out
you are selecting and sends the notification. The problem is that it
doesn't send the SWT.Selection event until after all this happens which
means that your code doesn't run until later. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=26605
news:cs1a7e$iqh$1@www.eclipse.org...
real
> --Vivian
> import org.eclipse.swt.widgets.Display;
> SWT.LEFT,
> SWT.LEFT };
> static {
> public static void main(String[] args) {
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
> new Table(parent,
> updateSelection();
> refresh();
> widgetSelected(e);
> updateSelection();
> updateSelection();
> addRow();
> refresh();
> | SWT.SHADOW_IN);
> } else {
> // Column 2: Name
> editor.layout();
> updateSelection();
> contains
> the
table.
> > The
the
> the
highlight
> > annoying.
to
> > > --Vivian
FUDForum. Page generated in 0.02937 seconds
