Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Solaris GTK 3.1M4 and libgcc dependancy
Solaris GTK 3.1M4 and libgcc dependancy [message #448047] Wed, 29 December 2004 05:14 Go to next message
Arthur Gouros is currently offline Arthur GourosFriend
Folks,
Great to see that SWT for Solaris GTK is now part of the mainstream builds
- which now means I can stop doing them ports myself.
Just notice a linking issue when running my Solaris SWT application:
Exception in thread "main" java.lang.UnsatisfiedLinkError:
/usr/lib/managesoft/swt-gtk/libswt-pi-gtk-3116.so: ld.so.1:
/usr/j2sdk1.4.2_04/jre/bin/java: fatal: libgcc_s.so.1: open failed: No
such file or directory.
Which I think this is telling us that SWT for Solaris GTK has a dependancy
on libgcc_s.so which is something you don't really want to ship to make
SWT work.
I had a look at the makefile, and found I needed to make the following
changes to remove this dependancy (note I am using gcc 3.3.2):
1) The "-shared" references in variable LIBS became "-O2 -G". variable
AWT_LIBS was not changed.
2) The "-O" references in CFLAGS became "-O2 -G".
I also added the following variable to the makefile which I assume in your
environment is provided by a calling process:
CC=gcc
LD=gcc
CDE_HOME=/usr/dt
XTEST_LIB_PATH=/usr/X/lib
JAVA_HOME=/usr/java
AWT_LIB_PATH=$(JAVA_HOME)/jre/lib/sparc
-L$(JAVA_HOME)/jre/lib/sparc/motif21
And finally, I needed to edit os_structs.c to remove all references to
"screen_changed" because of the following compile error:
os_structs.c: In function `getGtkWidgetClassFields':
os_structs.c:1847: error: structure has no member named `screen_changed'
os_structs.c: In function `setGtkWidgetClassFields':
os_structs.c:1918: error: structure has no member named `screen_changed'
make: *** [os_structs.o] Error 1
I can't find anything on the Solaris web site to get my GTK devel files
updated which I think is the real isue here.
After these changes the source compiles fine and runs my application well.
I hope you can incorporate some of this info into your mainstream Solaris
GTK builds. If you would like me to raise a bug on any of this then please
indicate which of the above issues qualify.
Arthur Gouros
PS: A mainstream solaris GTK build for the x86 architecture would be nice
too.
Re: Solaris GTK 3.1M4 and libgcc dependancy [message #448162 is a reply to message #448047] Tue, 04 January 2005 17:11 Go to previous message
Steve Northover is currently offline Steve NorthoverFriend
Yes, please enter a bug report with the contents of this message. Thanks
for figuring this out.
"Arthur Gouros" <Arthur.Gouros@managesoft.com> wrote in message
news:cqtees$ijv$1@www.eclipse.org...
> Folks,
> SWT work.
> CC=gcc
> LD=gcc
> CDE_HOME=/usr/dt
> JAVA_HOME=/usr/java
> Cheers,
> Arthur Gouros
> too.
Previous Topic:modify listener for OleClientSite
Next Topic:After adding a selectionListener tree items don't expand on double-click
Current Time: Sun May 09 11:52:21 GMT 2021
Powered by FUDForum. Page generated in 0.01723 seconds
