Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Gradients in CTabFolder
Gradients in CTabFolder [message #448026] Sun, 26 December 2004 22:49 Go to next message
Axel Schlueter is currently offline Axel SchlueterFriend
Member
I'd like to get the same kind of gradients
in the selected tab of a CTabFolder like the
ones used in the Eclipse editor tabs. When
using CTabFolder#setSelectionBackground() with
vertical==false, the gradient spreads about
the whole CTabFolder width, but I'd like to
get a gradient just about the width of the
currently selected tab. Any ideas ?
TIA,
Axel
Re: Gradients in CTabFolder [message #448091 is a reply to message #448026] Fri, 31 December 2004 03:56 Go to previous message
Rein Nehe is currently offline Rein NeheFriend
One way to do it is: use ViewForm; put your toolbar as a "top right"
component, and put CLabel (with gradient) as a "top left" component.
Hope that helps, Rein
Axel Schlueter wrote:
> TIA,
> Axel
Previous Topic:How to do Dialog return a String?
Next Topic:Extending SWT Components
Current Time: Tue Apr 16 23:00:12 GMT 2024
Powered by FUDForum. Page generated in 0.99594 seconds
