Home » Eclipse Projects » Standard Widget Toolkit (SWT) » swt.internal classes usage?
swt.internal classes usage? [message #447983] Wed, 22 December 2004 14:51 Go to next message
Originally posted by: mnaglik.nospam.gazeta.pl
Swt implementation has internal package:
org.eclipse.swt.internal
Its implementation differ on platforms but is it acceptable to use it
outside org.eclipse.swt package for a specific platform?
Especially is the api going to change inside ie. 3.0 version of eclipse?
TIA
m.
Re: swt.internal classes usage? [message #448004 is a reply to message #447983] Thu, 23 December 2004 17:25 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
You should not access internal packages, since they differ between platforms
and are not guaranteed to remain compatible between releases. If there is
some functionality that you need that is missing from swt's public api then
you may wish to log a Feature Request with Platform - SWT. Alternatively,
you may also be able to just copy the internal part(s) that you need to your
own package so that you're not affected by future swt changes.
Grant
"marcin naglik" <mnaglik@nospam.gazeta.pl> wrote in message
news:cqc1lq$6j5$1@www.eclipse.org...
> TIA
> m.
Re: swt.internal classes usage? [message #448038 is a reply to message #448004] Tue, 28 December 2004 09:52 Go to previous message
Thanks Grant,
m.
Previous Topic:Changer le contenu d'un Composite suivant un évènement
Next Topic:Are there some tools for test swt app?
Current Time: Sun May 16 11:03:47 GMT 2021
Powered by FUDForum. Page generated in 0.01832 seconds
