Home » Eclipse Projects » Standard Widget Toolkit (SWT) » 3.1 Stream Integration Build Wed, 1 Dec 2004
3.1 Stream Integration Build Wed, 1 Dec 2004 [message #446930] Mon, 06 December 2004 15:47 Go to next message
Patrik Mihailescu is currently offline Patrik MihailescuFriend
In the current stream build there is an unsatisfied link error running SWT
under the Pocket PC OS:
org/eclipse/swt/internal/win32/OS.GetDIBColorTable(III[B)I
when the following method is called:
org.eclipse.swt.widgets.ImageList.createMask
Patrik
Re: 3.1 Stream Integration Build Wed, 1 Dec 2004 [message #446940 is a reply to message #446930] Mon, 06 December 2004 19:04 Go to previous message
Christophe Cornu is currently offline Christophe CornuFriend
Thanks Patrik. The fix has been released in head and will be available in
tomorrow's integration build.
Chris
Previous Topic:Redrawing newly created widget
Next Topic:CCombo redraws slightly not wide enough for all items
Current Time: Tue May 18 09:14:50 GMT 2021
Powered by FUDForum. Page generated in 0.01635 seconds
