Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TableViewer
TableViewer [message #445187] Wed, 27 October 2004 17:08 Go to next message
Originally posted by: js.ekkono.com
Hi Everybody,
I have a lot of experience with Swing and start to explore SWT/JFace
slowly. So I have a bunch of questions, if you know a place I could look
them up, I would appreciate the pointer.
1) I am trying to create a table where the user can reorder columns
interactively?
2) Is there a standard way to make the configuration of a Table persistent?
3) Why are there properties and column numbers, and why do I have to keep
them in sync manually? Wouldn't it be easier to have only one way of
referencing a column? If properties is the standard way of referencing to
columns in JFace , I think it would be good, if the column indexes would
be hiden inside it. Or is there a reason why not?
Thanks for any help,
js
Re: TableViewer [message #445234 is a reply to message #445187] Fri, 29 October 2004 12:13 Go to previous message
Originally posted by: micasim.gmx.de
On Wed, 27 Oct 2004 17:08:17 +0000 (UTC), Joerg Schmuecker <js@ekkono.com>
wrote:
> Hi Everybody,
> interactively?
> persistent?
> to
> js
Hi Joerg,
1) Use org.eclipse.jface.viewers.TableViewer.setSorter
(org.eclipse.jface.viewers.ViewerSorter sorter) to sort the elements Add a
SelectionListener on the underlying Table to listen for the selection of a
column header, that initiates the sorting.
2) Don't exactly know you mean, but I guess
org.eclipse.jface.preference.[I]PreferenceStore is what you after.
3) I cannot aswer this question, in fact, I'm asking it myself. For me
it's just bad design. You will see it's not the only one in TableViewer /
TreeViewer
some links
<a
href=" http://www.eclipse.org/articles/Article-Table-viewer/table_v iewer.html">Building
and delivering a table editor with SWT/JFace</a>
<a
href=" http://www-106.ibm.com/developerworks/edu/j-dw-java-swing2sw t-i.html">Migrate
your Swing application to SWT</a>
<a
href=" http://www-106.ibm.com/developerworks/java/library/os-ecgui1 /">Using
JFace and SWT in stand-alone mode</a>
<a
href=" http://www-106.ibm.com/developerworks/java/library/os-ecgui2 /">Using
the JFace image registry</a>
<a
href=" http://www-106.ibm.com/developerworks/java/library/os-ecgui3 /">Adding
actions, menus, and toolbars</a>
hope this helps,
Michael
Previous Topic:I meet control paint trouber , pls help me!
Next Topic:CLabel's don't do mnemonics?
Current Time: Fri Oct 23 03:32:35 GMT 2020
Powered by FUDForum. Page generated in 0.02083 seconds
