KeyEvent for Text [message #445149] |
Wed, 27 October 2004 07:42 |
Originally posted by: nvragh.yahoo.co.uk
In my application, KeyEvent is fired only for Text (that too only visible
text). Not for Label. (Pasted the demo code below)
Can anyone throw some light on this, pls. It's little bit urgent.
Also, can i add keylistener to a shell?
If possible, reply me @ nvragh@yahoo.co.uk.
public class HelloWorld
public static void main (String [] args)
Display display = new Display ();
Shell shell = new HelloWorld().open (display);
while (!shell.isDisposed ())
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
public Shell open (Display display)
final Shell shell = new Shell (display);
Label label = new Label (shell, SWT.CENTER);
label.setText ("Hello_world");
label.pack();
Text text = new Text(shell, SWT.RIGHT);
text.setText ("Text");
text.pack();
text.setVisible(true);
shell.addListener(SWT.F2, new Listener()
public void handleEvent(final Event event)
System.out.println("F2 in addListener");
label.addKeyListener(new KeyAdapter(){
public void keyPressed(KeyEvent e)
//This is not at all getting executed
int code = e.keyCode;
System.out.println("Label Key code : "+code);
System.out.println("Label Key character: "+e.character);
if(code == 16777227)
System.out.println("Label F2F2F2F2F2F2F2!!!!!!!!!!!!!");
shell.dispose();
text.addKeyListener(new KeyAdapter(){
System.out.println("Text Key code : "+code);
System.out.println("Text Key character: "+e.character);
System.out.println("Text F2F2F2F2F2F2F2!!!!!!!!!!!!!");
shell.dispose();
shell.pack();
shell.open ();
return shell;
Re: KeyEvent for Text [message #445183 is a reply to message #445149] |
Wed, 27 October 2004 15:23 |
Steve Northover Messages: 1636 Registered: July 2009 |
Key events are only fired for the control that has focus. Labels don't take
focus. Key events are not inherited in SWT so a key listener in the shell
will only be fired when the shell itself has focus, not when a child has
focus.
"nvragh" <nvragh@yahoo.co.uk> wrote in message
news:clnji0$ho4$1@eclipse.org...
> Hello,
> Thanks
> display.dispose ();
> label.pack();
> text.pack();
> shell.dispose();
> shell.dispose();
> shell.pack();
> shell.open ();
> return shell;
Re: KeyEvent for Text [message #445206 is a reply to message #445183] |
Thu, 28 October 2004 12:02 |
Thanks a lot for your reply. One small clarification. As per the
information i collected after searching this forum, I came to know that i
can grab the keyevent globally (irrespective of which item has focus) if i
use Display.addFilter(event,listener). But, the handleEvent method of my
addFilter listener is not getting called.
I have two text's in my shell. I added keylistener for only one text and
added filter for the display as follows. If the focus is in other text,
the event is not fired. Anything i am doing wrong?
Code:
getShell().getDisplay().addFilter(SWT.F2,new Listener(){
public void handleEvent(Event e)
System.out.println("11111111");
text1.addKeyListener(new KeyAdapter(){
if(code == SWT.F2)
System.out.println("2222222");
> focus.
> > Hello,
> > Thanks
> > display.dispose ();
> > label.pack();
> > text.pack();
> > shell.dispose();
> > shell.dispose();
> > shell.pack();
> > shell.open ();
> > return shell;
Re: KeyEvent for Text [message #445212 is a reply to message #445206] |
Thu, 28 October 2004 13:49 |
Try "addFilter(SWT.KeyDown, ..." rather than "addFilter(SWT.F2, ...". That
should work but be warned that your filter will be called for every key that
is pressed in every shell on the display.
news:clqn51$j8f$1@eclipse.org...
> Code:
> if(code == SWT.F2)
take
shell
> > focus.
> > > Hello,
visible
> > > Thanks
> > > display.dispose ();
> > > label.pack();
> > > text.pack();
> > > shell.dispose();
> > > shell.dispose();
> > > shell.pack();
> > > shell.open ();
> > > return shell;
FUDForum. Page generated in 0.01895 seconds
