product deployment problem [message #437804] |
Wed, 05 October 2005 07:32 |
Originally posted by: sebastien.dilogos.com
Hi everybody,
I have a small problem with an Eclipse RCP product. I use Eclipse 3.1.
My product works fine when running in the Eclipse workspace.
When I use the Eclipse Product Export Wizard, in the product Overview,
This wizard create a directory with some files, and an executable
my_product.exe.
The problem is that when I click on this executable, I see the splash
screen of my product and then an error message appear : "An error as
occured, see the log file".
The log file contains that :
!SESSION 2005-10-05 09:17:34.968
eclipse.buildId=unknown
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_BE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-10-05 09:17:35.765
!MESSAGE An error occurred while automatically activating bundle
scenery.rcp (24).
!STACK 0
org.osgi.framework.BundleException: The activator scenery.rcp.RcpPlugin
for bundle scenery.rcp is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:151)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:321)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:266)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1259)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:222)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.ClassNotFoundException: scenery.rcp.RcpPlugin
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:403)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:144)
... 27 more
Root exception:
!ENTRY org.eclipse.osgi 2005-10-05 09:17:35.781
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException[1]:
java.lang.ClassNotFoundException: scenery.rcp.Application
What can I do for my product to work standalone ?
Thanks a lot,
Sébastien
Re: product deployment problem [message #437807 is a reply to message #437804] |
Wed, 05 October 2005 10:04 |
Mike Haller Messages: 11 Registered: July 2009 |
Junior Member |
Check your exported jar file scenery.rcp_1.0.0.jar or something has your
classes in it.
If not, open your manifest.mf editor and check:
- Tab "Runtime", Section "Classpath" includes an entry "." and all your
other folders containing resources and all jars of requires libraries.
- Tab "Build", Section "Runtime Information" also contains the "."
entry. When clicking on that, you should see "src/" or "src/java" on the
right side.
- Tab "Build", Section "Binary Build", check that all folders containing
resources are checked (e.g. etc/, lib/, icons/ and alike), also META-INF
and plugin.xml should be checked.
Go to the product configuration editor and check if you are using
"plug-ins" or "features" for your plugin. ("The product configuration is
based on:").
If based on plugins, you can go directly to the configuration tab and
check your plugins.
If based features, go to the "Configuration" tab and double-click the
feature set. Then, go to the "Plug-Ins" tab in the feature.xml and check
that you included all your plugins.
Hope this helps.
If not, give us some more information.
Seb Vandamme schrieb:
> Hi everybody,
> my_product.exe.
> scenery.rcp (24).
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 27 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks a lot,
> Sébastien
Re: product deployment problem [message #437813 is a reply to message #437804] |
Wed, 05 October 2005 12:50 |
Originally posted by: wang_w_t.hotmail.com
maybe you forgot something in your product file,
in the configuration page of product
add your plugin and add required plug-ins
don't forget to synchronize
hope to help
wwt
FUDForum. Page generated in 0.03220 seconds
