Customize window layout of menu bar [message #437632] |
Fri, 30 September 2005 12:37 |
Lorenz Maierhofer Messages: 88 Registered: July 2009 |
Member |
--------------030206050806070109070502
Hi all,
I have found some window layout modification code in the Browser
example, and now I am wondering if some modification would be possible
to make an RCP app look like an MS office app.
What I mean is:
In e.g. Word the "close this editor"-Button is top-right on the height
of the menu bar. See attached image.
I could not find any obvious way to put a button at that location, since
the menu bar is directly set to the shell using setMenuBar().
Any ideas?
regards,
Lorenz
Content-Type: image/gif;
name="Image1.gif"
Content-Disposition: inline;
filename="Image1.gif"
R0lGODlheAAyAPcAAAAAAEBAQICAgJ6enqCgoKampo6x24+x3I+y3JCy3ZCz 3ZGz3pG03pK0
3pK135O135O24JS34JS34ZW34ZW44ZW44pa54pa545e645i75Jm85Zm95Zq9 5Zq95pu+5pu/
55y/55zA6J3A6J3B6J7B6Z7C6Z/C6p/D6qDD66DE66HE66HF7KLF7KLG7aPH 7aPH7qTH7qTI
7qTI76XJ76bK8MnIxs3NzNTQyObj3+bk3+bk4Ofk4Ofl4Ofl4ejl4ejl4ujm 4ujm4+nm4+nn
4+nn5Orn5Oro5Oro5evp5evp5vTz8fX08v///wAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACwAAAAAeAAyAAAI/gCZCBxIsKDB gwgTKlzIsKHD
hzciSpxIsaLFixgzatzIsWPHAA9DihxJsmRDAQE8qlzJsqVLjihfypxJs6ZE lAYOHECQQIGC
BQwaOHDwAAKECBImUKhgwcIFDBgySNWgYQOHDh48fAABIoSIESRIlDBx4gSK FCpWrGDRooWL
FzBiyJgxg4bdu3jz6t3Lt2/fiDh18vQJVChRo0iVMnUKVWoGqlaxauXqFaxY smbRqmXrFq5c
un5Dix7NF3CAnDt7/gw6tOjRpEubPo06terVrFu7fg07tuzZtGvbvo07ty6N hyAdBrCL3K5p
1INXG3adODZj2o9tS85dmTfm35uF/nsuzhwmSPPlN6J0fiNwasKsD79WLLtx 7ci4Ke++7Ftz
8M7EgXaceUxEBMCBCCJoWnoarUfDc4KpVlhriMG22GyOQXbbZLpZ1ltmwHE2 3GfGFajeeTck
qOKCAxoIwEQHsgjhe9JROJ91GN63IXf7fQjefyOS12KDKL5YkZEOmujikjK2 d1qE8E1XIX3X
Zahdfh1611+I4gVYIoEGWoTkckO6GONNZM4Y3YTyVXehfdnhx2F3/IEYHoAk MpgRSiYaSdGY
ejKJJnvurRkfdRbWh52G2+nn4Xf+iTiegEruWaSYLFaaooKDPugkdBIeOiWO cDKKJZ0+Rtpl
nmVixGeY/kdmCqORZzpJ6JM0sokolTnGuaOjWtoJ5KRfmsmpaX1iauuQtW7a ZKGhSnnjm4te
OWePkHKJp5BKquink316e2aS6HkKbZQ2uqmolXLy+OiWdwZJKZgnBnqRg2pG m26iVerYaJZ1
/iipl8wJYPDBCCMMUsIMH0wmEw03nOanUNbYJr+9mnrtu8IOzGoAIIcs8sgk lyyyXSabfCuo
6F7Ma6nWuhuswKsKSdrNOO+Vb8u7klptu8AGrOq2AuZsdM6m2aT00kzfGwAO UEeNQw5U56DD
1VhjvcPWXPPQw9dghx22Dz788AMQaKetdtpBtC3E20PELffcRNRtd91FGKH3 /t5GHOH334D7
jcTgSCRh+OGImyZ11FVbnXXWXHct9uRgk2322pij3XYQbwsx9+dD3H133nzr HfjpRxBeOOKs
K7741FU/DnnkO3hN+eSWn5352pt3DjrdouNduumoA6466607+TrsVMuuNe22 3z522brvzrbb
cP8ed/DCD1+88YQjn7jyrzfu/NW01y692Llbr3bv2WvPPRGkl/7938eLb7jr i5t/fvrRW18P
2uc+zWHPc9oLHffqx7f7CS58+ksC/6TmP+cBUICVo14BDci5+P1ufgzcmwNT B0H9TZBxsfsf
9DD4NQIWEH4IlN8Ch9c3ByLhQKtLwoGSh5LlmU9F/s+LXADDBgD2aXCDMBwC gkAHQhqOcHA7
1CEAkHdCqP3QgiukXBGndzkkHnBuAPhcE71nQygiSHxVZJ7VACA7BG0tQWBD UA/kOMcDmQ0A
QMCj9ZIotzACL3ghJN79VBdFKpKvf7EDIhvfuAMAqK+IW/xaJItINgD84EAv /GLc/PhH0QWy
hoM0YyHH18PyJfJxKmrkI+sYxzgm6JJe7CACOdnJ0TmxjFEc5f4OScFTZm2R XHOk1yYJyVbm
To/u4yMt5TZG+9kQh4fTZRqv+EsdMFKYcyRiNiU5QB9YEpl71KQMAXnLUA4u ghLkJQqbx0ZU
HoiRw6wjMSVpR1hmUpab7PzgDMlozhyiUZ1WTCEWhcjCbnbxnr5LYDMbWMZz RnCaiQSiNbOI
QRcm84sqqqXdPvnEEv6zlIhsngoJykKLhhOfCt2nM/uJToiKdKCSK+kREepB JqqUoSx9KEDV
eL6JkrSiM70oSsfpyXJ+L38m3GkFZXdBmR5UqAklqi35eVSPGhKkvXwpUykq QJPujo9S3ahR
i4fUjz7NlFp9XFOB+tSTRlWf5KQqWa3KwwAs4a54zate98rXvvr1r4ANrGAD a4MCEOCwiEVs
DdKJEiU49rGQjaxkJ0vZylr2spjNbGZtMIDOetazBaiBaQICADs=
--------------030206050806070109070502--
FUDForum. Page generated in 0.03010 seconds
