Home » Eclipse Projects » Rich Client Platform (RCP) » documentation on update manager
documentation on update manager [message #437325] Tue, 27 September 2005 13:03 Go to next message
Andreas Pakulat is currently offline Andreas PakulatFriend
I'd like to know if there is any howto or documentation how one could
write his own update manager (with the purpose of installing/updating
features without any user-interaction)?
The reason I'm asking is that I'm not quite comfortable with using
classes from org.eclipse.update.internal, but I have to if I don't want
to just copy these codes into my own classes.
Also installing works, but is executed even if the features are already
installed and updating doesn't quite work.
Andreas
Re: documentation on update manager [message #437330 is a reply to message #437325] Tue, 27 September 2005 14:18 Go to previous messageGo to next message
Geoff Draper is currently offline Geoff DraperFriend
Member
I found the following tutorial very helpful for integrating Update Manag=
er =
into my RCP application:
http://www.eclipsecon.org/2005/presentations/EclipseCon2005_ Tutorial8.pd=
f
On Tue, 27 Sep 2005 07:03:10 -0600, Andreas Pakulat =
<pakulat@rostock.zgdv.de> wrote:
> I'd like to know if there is any howto or documentation how one could =
> write his own update manager (with the purpose of installing/updating =
> The reason I'm asking is that I'm not quite comfortable with using =
> classes from org.eclipse.update.internal, but I have to if I don't wan=
t =
> Also installing works, but is executed even if the features are alread=
y =
> Andreas
Re: documentation on update manager [message #437332 is a reply to message #437330] Tue, 27 September 2005 14:33 Go to previous messageGo to next message
Problem is: I don't want to integrate the Eclipse Update Manager into my
app, as I want non-ui automatic updates/installation of features.
Andreas
> Manager into my RCP application:
> http://www.eclipsecon.org/2005/presentations/EclipseCon2005_ Tutorial8.pdf
>> want to just copy these codes into my own classes.
>> already installed and updating doesn't quite work.
>> Andreas
Re: documentation on update manager [message #437333 is a reply to message #437332] Tue, 27 September 2005 14:42 Go to previous messageGo to next message
arne anka is currently offline arne ankaFriend
maybe i'm wrong, but i think this is accomplished by using a
plugin_customization.ini and three or four entries triggering automatic
update on startup.
Re: documentation on update manager [message #437467 is a reply to message #437333] Thu, 29 September 2005 08:16 Go to previous messageGo to next message
>> my app, as I want non-ui automatic updates/installation of features.
> update on startup.
Is there documentation about this anywhere?
I guess this doesn't involve automatic installation of new features?
Andreas
Re: documentation on update manager [message #437471 is a reply to message #437467] Thu, 29 September 2005 10:12 Go to previous messageGo to next message
there was a thread recently, you might search at
http://www.eclipsezone.com/eclipse/forums/c5605.html
don't know -- but should be possible.
Re: documentation on update manager [message #437473 is a reply to message #437325] Thu, 29 September 2005 12:09 Go to previous message
Peter Manahan is currently offline Peter ManahanFriend
Andreas Pakulat wrote:
> Andreas
The API in org.eclipse.update.core (operations,search,standalone)
doesn't give you enough control? I believe its intention was to allow
exactly what you want to do.
Peter
Previous Topic:Problems updating features
Next Topic:Undo in RCP app
Current Time: Sun Dec 08 03:13:01 GMT 2024
Powered by FUDForum. Page generated in 0.03449 seconds
