Home » Eclipse Projects » Rich Client Platform (RCP) » Show a view as a 'detached view' by code ?
Show a view as a 'detached view' by code ? [message #437150] Thu, 22 September 2005 21:29 Go to next message
Stephane  fournier is currently offline Stephane fournierFriend
Does anyone have any idea to achieve that ?
Stephane.
Re: Show a view as a 'detached view' by code ? [message #437218 is a reply to message #437150] Fri, 23 September 2005 12:05 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
> Stephane.
Do a google search: site:dev.eclipse.org news.eclipse detached view
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg07130.html
Later,
PW
Re: Show a view as a 'detached view' by code ? [message #437228 is a reply to message #437218] Fri, 23 September 2005 16:25 Go to previous messageGo to next message
Ben Brown is currently offline Ben BrownFriend
Yeah this question turns up often, turns out the patch won't work for
various reasons, mainly the DetachedWindow class no longer extends
Window. I'm still working on trying to create a new patch, things do
not look promising at this point though.
>> Stephane.
> Later,
> PW
Re: Show a view as a 'detached view' by code ? [message #437229 is a reply to message #437228] Fri, 23 September 2005 17:03 Go to previous messageGo to next message
I know it's not API and doesn't help with actually setting up a layout,
but there is a way to do it for specific releases of Eclipse
programatically (once eclipse is up and running).
WorkbenchPage page = WorkbenchPage)window.getActivePage();
page.detachView(IViewReference)
It's an internal method, so there's no gaurantee that it'll stay in that
class or form, but it works.
Later,
PW
Re: Show a view as a 'detached view' by code ? [message #437230 is a reply to message #437229] Sat, 24 September 2005 08:56 Go to previous messageGo to next message
Thanks for the tip but it could not work with 3.1 or 3.2M1 due to
restrictions access on the required library
org.eclipse.ui.workbench_3.2.0.jar .
Do you know if a public API will be offered in 3.2 to figure out that
issue ?
Stephane.
> Later,
> PW
Re: Show a view as a 'detached view' by code ? [message #437261 is a reply to message #437230] Mon, 26 September 2005 12:39 Go to previous messageGo to next message
It's true that those APIs are restricted, but unless you activate some
kind of strict compliance, it won't prevent you from doing stuff.
> issue ?
My guess is no, monitor https://bugs.eclipse.org/bugs/show_bug.cgi?id=70050
PW
Re: Show a view as a 'detached view' by code ? [message #437273 is a reply to message #437261] Mon, 26 September 2005 19:31 Go to previous messageGo to next message
I assume that I should alter the MANIFET.MF for the Wrokbench Plugin ?
Stephane
>> issue ?
> PW
Re: Show a view as a 'detached view' by code ? [message #437323 is a reply to message #437273] Tue, 27 September 2005 13:01 Go to previous messageGo to next message
I don't believe so ... it should be giving discouraged access warnings,
but there's nothing that prevents it from compiling or running (unless
you somehow activate strict compliance).
Later,
PW
Re: Show a view as a 'detached view' by code ? [message #437524 is a reply to message #437229] Thu, 29 September 2005 15:38 Go to previous messageGo to next message
Thanks Paul,
You don't also happen to know if there is a way to position and resize
the view after detaching using this methodology do you?
--Ben
> Later,
> PW
Re: Show a view as a 'detached view' by code ? [message #437530 is a reply to message #437524] Thu, 29 September 2005 16:29 Go to previous messageGo to next message
Ben Brown wrote:
> Thanks Paul,
> --Ben
I don't remember seeing anything ... maybe you can get ahold of it's
detached window shell and resize and move that.
Later,
PW
Re: Show a view as a 'detached view' by code ? [message #437736 is a reply to message #437323] Mon, 03 October 2005 17:35 Go to previous messageGo to next message
I do not have customized Eclipse. I am running Eclipse/RCP 3.2M2 win32
with JRE_1.5.0-04.
When I am lauching the RCP app, it warns me there are errors... Indeed,
when running I got exceptions...
ErrorLog :
java.lang.Error: Unresolved compilation problems:
Discouraged access: The type WorkbenchPage is not accessible due to
restriction on required library
C:\outils\sdk\3.2M1\eclipse\plugins\org.eclipse.ui.workbench _3.2.0.jar
The discouraged access are not warnings but errors into the ErrorLog
Any idea to turn off strict compliance ?
Stephane.
> Later,
> PW
Re: Show a view as a 'detached view' by code ? [message #437739 is a reply to message #437736] Mon, 03 October 2005 19:25 Go to previous message
Ok I figured out my problem with quick fix and configuring acces rules !!!
> with JRE_1.5.0-04.
> ErrorLog :
> Stephane.
>> warnings, but there's nothing that prevents it from compiling or
>> running (unless you somehow activate strict compliance).
>> Later,
>> PW
Previous Topic:RCP Text Example under 3.1?
Next Topic:Several questions to be asked.
Current Time: Sun Dec 08 23:04:08 GMT 2024
Powered by FUDForum. Page generated in 0.04270 seconds
