Home » Eclipse Projects » Rich Client Platform (RCP) » Forcing start of a plugin
Forcing start of a plugin [message #437034] Tue, 20 September 2005 18:26 Go to next message
Markus Wolf is currently offline Markus WolfFriend
Hi there,
is there a way to force the start of a plugin.
My plugin is resolved but not activated when I test it.
Adding a bundle header 'Eclipse-AutoStart: true' is not enought.
Markus Wolf
> emedia-solutions wolf
> Wedeler Landstrasse 63
> 22559 Hamburg
>> phone: (+49) 40 550 083 70
>> web: http://www.emedia-solutions-wolf.de
>> mail: markus@emedia-solutions-wolf.de
>> pgp: http://wwwkeys.de.pgp.net
Re: Forcing start of a plugin [message #437036 is a reply to message #437034] Tue, 20 September 2005 18:28 Go to previous messageGo to next message
Shame on me. I should read the newsgorup before I post here....
*feels ashamed*
> 22559 Hamburg
Re: Forcing start of a plugin [message #437038 is a reply to message #437034] Tue, 20 September 2005 19:06 Go to previous messageGo to next message
One questions comes to my mind when I implemented the IStartup interface.
Why does it depends on org.eclipse.ui? With that I get a dependency on
ui plugins and jface.
This is just bad for my case, because I want to use eclipse in a
headless environment and it makes no sense to that IStartup is needing a
graphical user interface. *confused*
Can anyone clear my mind on this?
Markus Wolf
> 22559 Hamburg
Re: Forcing start of a plugin [message #437041 is a reply to message #437038] Wed, 21 September 2005 02:21 Go to previous messageGo to next message
sck is currently offline sckFriend
Member
I am not sure why did that...
But, I can give you the following idea to do that...if you always want the
plug-in to be loaded at start up,
1) create a dummy class in the plug-in that has to be loaded at start up.
2) have your RCP plugin create an instace of this dummy class.
-Sridhar
"Markus Wolf" <markus@emedia-solutions-wolf.de> wrote in message
news:dgpmjp$rdr$1@news.eclipse.org...
> Regards
> Markus Wolf
>> 22559 Hamburg
Re: Forcing start of a plugin [message #437126 is a reply to message #437041] Thu, 22 September 2005 00:39 Go to previous messageGo to next message
Haris Peco is currently offline Haris PecoFriend
or call Plugin.getDefault() in window advisor
or see Eclipse-AutoStart directive in MANIFEST.MF
> -Sridhar
>> Regards
>> Markus Wolf
>>> 22559 Hamburg
Re: Forcing start of a plugin [message #437145 is a reply to message #437126] Thu, 22 September 2005 16:52 Go to previous messageGo to next message
That's a good idea. Thanks. :-)
btw. Just setting Eclipse-AutoStart to true is not enought.
Markus Wolf
> 22559 Hamburg
Re: Forcing start of a plugin [message #437154 is a reply to message #437145] Fri, 23 September 2005 02:46 Go to previous messageGo to next message
> Markus Wolf
there is Platform.getPlugin(), but loading plugin on startup isn't good idea
Re: Forcing start of a plugin [message #437155 is a reply to message #437154] Fri, 23 September 2005 06:44 Go to previous message
I know. I also know about lazy loading, start-up time and everything
else. But sometimes it is just neccessary.
> 22559 Hamburg
Previous Topic:Unhandled event loop exception
Next Topic:Page not available when view is initialized
Current Time: Mon Dec 09 06:30:26 GMT 2024
Powered by FUDForum. Page generated in 0.03264 seconds
