Home » Eclipse Projects » Rich Client Platform (RCP) » Unhandled event loop exception
Unhandled event loop exception [message #437033] Tue, 20 September 2005 18:24 Go to next message
Originally posted by: jweng.us.ibm.com
We developed a plug-in on Eclipse 3.1. We use plug-in to call the
jasperreoprt class (We registered jasperreport class and all its jar files
as third party in plug-in). The jasperreport works fine in RAD (Rational
Application Developer) and RSA (Rational Software Application)
environment. When we run the plugin, we got the following exception:
Reason:
net/sf/jasperreports/engine/fill/JRFillParameter
We check it in the .metadata/.log file. It says the above file could not
be found. We run the
Class.forName("net.sf.jasperreports.engine.fill.JRFillParameter ").getName()
and also check it in the Eclipse prospective, it is there. Does anyone
have any idea of this error? Thank you in advance for your input.
John
Re: Unhandled event loop exception [message #437044 is a reply to message #437033] Wed, 21 September 2005 06:00 Go to previous messageGo to next message
Reinhard Moser is currently offline Reinhard MoserFriend
Member
Hi John,
i had a similar problem. I am using log4j as logging facility in my
rcp application. I tried to create a new plugin from existing jars. I
add the new log4j-plugin to my dependencies. Also a
ClassNotFoundException occured. The only way to correct this was to add
log4j.jar to my plugin. I think it has something to do with the class
loaders. Each plugin has a own class loader
Hope this helps
Kind regards
Reinhard
John Weng schrieb:
> files as third party in plug-in). The jasperreport works fine in RAD
> (Rational Application Developer) and RSA (Rational Software Application)
> Reason:
> Thanks
> John
Re: Unhandled event loop exception [message #437120 is a reply to message #437044] Wed, 21 September 2005 15:24 Go to previous messageGo to next message
Hi, Reinhard
Thank you for your input! I try to put the log4j.jar file in my plugin,
it still gave me the same error message. I use the log4j-1.2.8.jar. Which
versionof log4j file you use? Thank you again for your answer......
John
Re: Unhandled event loop exception [message #437124 is a reply to message #437120] Wed, 21 September 2005 22:41 Go to previous messageGo to next message
Haris Peco is currently offline Haris PecoFriend
John Weng wrote:
> Hi, Reinhard
> John
John
Problem with log4j is for log4j classes
You have another problem and it is eclipse classloader problem
search my thread in eclipse.platform
http://dev.eclipse.org/newslists/news.eclipse.platform/msg44 996.html.
I have solution with my classloaders, but correct is change in eclipse
classloader (ContextFinder)
Re: Unhandled event loop exception [message #437128 is a reply to message #437120] Thu, 22 September 2005 06:44 Go to previous messageGo to next message
Member
Hi John,
i am using log4j version 1.2.8. You have to add the library also in
your plugin.xml file under Runtime->Classpath.
Reinhard
John Weng schrieb:
> Hi, Reinhard
> Which versionof log4j file you use? Thank you again for your answer......
> John
Re: Unhandled event loop exception [message #437141 is a reply to message #437124] Thu, 22 September 2005 15:52 Go to previous messageGo to next message
Thank you guys again for your input!!!
Snap, I believe the problem you described is what I encounter now. I never
use ClassLoader and ContextFinder before. Could you give me a simple
example to show me how the ClassLoader and ContextFinder associate with
the jasperreport on Eclipse? Thank you again for your help.
John
Re: Unhandled event loop exception [message #437143 is a reply to message #437124] Thu, 22 September 2005 16:10 Go to previous messageGo to next message
Hi, Reihard, snpe
I got my jasperreport running on Eclipse 3.1. You guys are so helpful for
me. Thank you again for your input!!!
John
Re: Unhandled event loop exception [message #437153 is a reply to message #437141] Fri, 23 September 2005 02:44 Go to previous message
> John
John,
have you solution for your problem ?
Previous Topic:Action with different names for toolbar and menu
Next Topic:Forcing start of a plugin
Current Time: Sat Dec 07 18:50:13 GMT 2024
Powered by FUDForum. Page generated in 0.04901 seconds
