lightweightsystem initialization failing [message #436755] |
Sat, 17 September 2005 09:17 |
Originally posted by: kevin.cs.washington.edu
Background:
I am changing the SWT text widget in the Message area of the RCP Mail
template to an SWT canvas, on which I hope to be able to draw labels
using draw2d.
Problem:
NOTE: My plugin-dependencies were set by Eclipse, and already include
org.eclipse.swt.win32.win32.x86_3.1.0.jar (which contains
AccessibleListener) AND org.eclipse.swt_3.1.0.jar (which is empty).
When I try to instantiate LightwightSystem:
createCanvas();
lws = new LightweightSystem(canvas);
I get this runtime error:
!SESSION 2005-09-17 04:10:05.625
eclipse.buildId=unknown
java.version=1.5.0_04
Framework arguments: -product force.product -pdelaunch
Command-line arguments: -product force.product -data
c:\eclipse\runtime-force.product -dev
file:c:/eclipse/workspace/.metadata/.plugins/org.eclipse.pde .core/force.product/dev.properties
-pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-09-17 04:10:07.390
!MESSAGE Bundle
initial@reference:file:plugins/com.ibm.etools.emf.event_3.0.0.1/
was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-09-17 04:10:07.390
!MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.0.0,3.0.0).
org.eclipse.core.runtime.compatibility_0.0.0.
!ENTRY org.eclipse.osgi 2005-09-17 04:10:10.953
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError:
org/eclipse/swt/accessibility/AccessibleListener
at force.View.createPartControl(View.java:51)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:305)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:180)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:51 2)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1051)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 56)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:576)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:528)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:485)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:230)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:813)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2165)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:2356)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2338)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:681)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:669)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1282)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1223)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:706)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at force.Application.run(Application.java:22)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.osgi 2005-09-17 04:10:10.968
!MESSAGE Bundle
initial@reference:file:plugins/com.ibm.etools.emf.event_3.0.0.1/ [17]
was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-09-17 04:10:10.968
Re: lightweightsystem initialization failing [message #436756 is a reply to message #436755] |
Sat, 17 September 2005 10:04 |
I should also note that importing org.eclipse.wt.accessibility.*; does
not help.
Kevin Chiu wrote:
> Hello,
> Background:
> using draw2d.
> Problem:
> createCanvas();
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !MESSAGE Bundle
> was not resolved.
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Bundle
> was not resolved.
Re: lightweightsystem initialization failing [message #436757 is a reply to message #436756] |
Sat, 17 September 2005 10:05 |
Oops, I meant importing org.eclipse.swt.accessibility.*; does not help.
(typo)
> not help.
> Kevin Chiu wrote:
>> Hello,
>> Background:
>> using draw2d.
>> Problem:
>> createCanvas();
>> !MESSAGE Bundle
>> was not resolved.
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> !MESSAGE Bundle
>> was not resolved.
Re: lightweightsystem initialization failing [message #436759 is a reply to message #436755] |
Sat, 17 September 2005 16:22 |
Pratik Shah Messages: 1077 Registered: July 2009 |
Kevin, GEF and draw2d are not mentioned in the error stack trace. The log
also mentions you seem to be missing required plugins (emf.ecore and
runtime.compatibility). Check to see who's requiring those plugins. The
SWT jar being empty doesn't sound right either. You might want to pursue
this further on the swt or platform newsgroup.
"Kevin Chiu" <kevin@cs.washington.edu> wrote in message
news:dggu0i$473$1@news.eclipse.org...
> Hello,
> Background:
> using draw2d.
> Problem:
> createCanvas();
> !MESSAGE Bundle
> was not resolved.
> !STACK 1
> at
5)
> at
> at
e.java:552)
> at
Part.java:126)
> at
> at
> at
> at
a:1102)
> at
va:485)
> at
0)
> at
> at
> at
338)
> at
1)
> at
> at
> at
> at
figurer.java:190)
> at
a:706)
> at
> at
java:226)
> at
> at
> at
> at
..java:25)
> !MESSAGE Bundle
> was not resolved.
FUDForum. Page generated in 0.05842 seconds
