Home » Eclipse Projects » Rich Client Platform (RCP) » Hook before the workbench state is closed?
Hook before the workbench state is closed? [message #436720] Thu, 15 September 2005 13:18 Go to next message
Florian Thienel is currently offline Florian ThienelFriend
Hi!
Is there a hook method that is called before when the main window is
closed but before the workbench state is stored?
In my application I need to close some editors when the application is
closed to prevent this editors from beeing opened when the application
is started again.
The method preWindowShellClose() only works for the case when the window
is closed by the user.
Florian
Re: Hook before the workbench state is closed? [message #436893 is a reply to message #436720] Tue, 20 September 2005 00:29 Go to previous messageGo to next message
Pascal Rapicault is currently offline Pascal RapicaultFriend
You should be able to find answers about this question searching the
archive of this newsgroup.
PaScaL
Florian Thienel wrote:
> Hi!
> is started again.
> Florian
Re: Hook before the workbench state is closed? [message #436922 is a reply to message #436720] Tue, 20 September 2005 09:13 Go to previous messageGo to next message
Stefan Langer is currently offline Stefan LangerFriend
Can't you use the stop method of the plugin that provides the editor to
close the editor manually?
Stefan
> Hi!
> is started again.
> Florian
Re: Hook before the workbench state is closed? [message #436926 is a reply to message #436922] Tue, 20 September 2005 10:07 Go to previous message
The stop method is called after the workbench window is closed so I
assume that information about the open editors is also written before
the invokation of the stop method.
I'll invesitgate the ISaveParticipat-mechanism next.
Florian
> Stefan
>> Hi!
>> is started again.
>> window is closed by the user.
>> Florian
Previous Topic:Internal Browser and title
Next Topic:How to open a custom IEditorInput in a single instance?
Current Time: Sun Dec 08 18:39:20 GMT 2024
Powered by FUDForum. Page generated in 0.02996 seconds
