Ok, I give up: Using 3rd party jars [message #436670] |
Wed, 14 September 2005 12:08 |
Originally posted by: kevin.cs.washington.edu
I'm having problems exporting my RCP application, despite following some
tips I found in the archives.
Setup:
1) Used Mail-App RCP template. The project name is "force".
2) Added some .java files and added some external .jar files (imported
into /lib, added to classpath on overview->runtime tab, correct
libraries exposed).
3) I notice there is no .product file.
4) I add a .product file based on Eclipse Application (1) (It works and
exports fine).
5) I run the exported eclipse.exe.
6) My custom splash screen pops up.
7) I get a prompt that tells me to look inside another file for an error.
8) I find this error in a .log file:
!SESSION 2005-09-14 06:51:39.406
eclipse.buildId=unknown
java.version=1.5.0_04
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-09-14 06:51:40.609
!MESSAGE An error occurred while automatically activating bundle force (1).
!STACK 0
org.osgi.framework.BundleException: The activator force.ForcePlugin for
bundle force is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:151)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:321)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:266)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1259)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:222)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.ClassNotFoundException: force.ForcePlugin
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:403)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:144)
... 27 more
Root exception:
!ENTRY org.eclipse.osgi 2005-09-14 06:51:40.625
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException[1]:
java.lang.ClassNotFoundException: force.Application
Re: Ok, I give up: Using 3rd party jars [message #436677 is a reply to message #436670] |
Wed, 14 September 2005 17:58 |
> Setup:
> libraries exposed).
> exports fine).
For some reason, the plugin exported with 3rd party jars has the jars
(assuming you've added them to the Build>binary build section), but
since it's deployed as a directory plugin the class files aren't there.
You have 2 choices:
1. Create a separate plugin with your third party jars by using the
create new plugin from jars wizard ... then depend on it.
2. If you create a new plugin with the 3rd party libraries as jars, or
add them as jars to your plugin, a workaround I found was
2a. go to the binary build section and include the folder bin
2b. add bin to the manifest classpath
then it works.
Later,
PW
Paul Webster
Re: Ok, I give up: Using 3rd party jars [message #436680 is a reply to message #436677] |
Wed, 14 September 2005 17:34 |
Paul Webster wrote:
>> some tips I found in the archives.
>> Setup:
>> libraries exposed).
>> and exports fine).
> You have 2 choices:
> then it works.
> Later,
> PW
I did number 1 and it worked. Thanks!
FUDForum. Page generated in 0.03362 seconds
