Home » Eclipse Projects » Rich Client Platform (RCP) » Invalid Menu Extension error messages.
Invalid Menu Extension error messages. [message #436516] Sat, 10 September 2005 19:44 Go to next message
Cedric Hyppolite is currently offline Cedric HyppoliteFriend
I am receiving the following error messages since I added the
org.eclise.ui.browser plugin to my RCP app.
I had to add the eclipse.core.ide plugin as it is required by the
browser plugin.
Now I get error about a menu/coolbar that don't exist.
Does anyone know how to get rid of these error for example by adding the
appropriate coolbar.
Cedric
!MESSAGE Invalid Menu Extension (Path is invalid):
org.eclipse.update.ui.updateMenu
Invalid Menu Extension (Path is invalid): org.eclipse.update.ui.updateMenu
!ENTRY
org.eclipse.ui 4 4 2005-09-10 21:37:55.567
org.eclipse.update.ui.configManager
!ENTRY org.eclipse.ui 4 4 2005-09-10 21:37:55.572
org.eclipse.update.ui.newUpdates
Invalid Menu Extension (Path is invalid): org.eclipse.update.ui.newUpdates
!ENTRY org.eclipse.ui 4 4 2005-09-10 21:37:55.576
org.eclipse.ui.actions.showKeyAssistHandler
!ENTRY org.eclipse.ui 4 4 2005-09-10 21:37:55.586
org.eclipse.ui.edit.text.gotoLastEditPosition
postWindowCreate (doing nothing)
2005-09-10 21:37:56.444 java[3449] GrP not requesting _registerDragTypes
because the window is dying already
Re: Invalid Menu Extension error messages. [message #436544 is a reply to message #436516] Tue, 13 September 2005 00:58 Go to previous messageGo to next message
Pascal Rapicault is currently offline Pascal RapicaultFriend
Those contributions are done by the ide or one of its prereq and they
can't be removed.
I just checked the browser dependency and don't see any necessity to
have ide loaded.
PaScaL
Cédric Hyppolite wrote:
> browser plugin.
> Cedric
> !ENTRY
Re: Invalid Menu Extension error messages. [message #436887 is a reply to message #436544] Mon, 19 September 2005 21:58 Go to previous messageGo to next message
Pascal,
You're right the ide is not required by the browser. But since I used
the browser
as an editor I added the ui.editor plugin which requires the ide.
I removed both plugins from the configuration. I still have the same error.
Cedric
> can't be removed.
> have ide loaded.
> PaScaL
>> browser plugin.
>> the appropriate coolbar.
>> Thanks,
>> Cedric
>> !ENTRY
>> _registerDragTypes because the window is dying already
Re: Invalid Menu Extension error messages. [message #436888 is a reply to message #436544] Mon, 19 September 2005 22:00 Go to previous message
Pascal,
the browser
Cedric
> can't be removed.
> have ide loaded.
> PaScaL
>> browser plugin.
>> Thanks,
>> Cedric
>> !ENTRY
Previous Topic:org.osgi.framework.BundleException
Next Topic:Problem starting RCP app that has been exported
Current Time: Sun Dec 08 22:09:00 GMT 2024
Powered by FUDForum. Page generated in 0.03367 seconds
