Home » Eclipse Projects » Standard Widget Toolkit (SWT) » problem in dialog window in linux ??
problem in dialog window in linux ?? [message #436131] |
Wed, 12 May 2004 05:10 |
Originally posted by: dashing_rastogi.yahoo.com
hi guys
here is a code snippet for creating dialog shell ..it works fine on
windows , means it doesnt show maximize,minimize button and you cant
resize it but on linux it shows maximize,minimize and i can even resize it
..can anyone suggest me some other way or tell me the problem in this ,
thanks in advance..
final Shell parent = getParent();
shell = new Shell(parent, SWT.DIALOG_TRIM | SWT.APPLICATION_MODAL);
Re: problem in dialog window in linux ?? [message #436134 is a reply to message #436131] |
Wed, 12 May 2004 08:08 |
Originally posted by: dumitru.frunza.moldsoft.com
achal rastogi wrote:
> hi guys
> thanks in advance..
Excerpt from the Shell's Javadoc:
"Note: The styles supported by this class (Shell) must be treated as
HINTs, since the window manager for the desktop on which the instance is
visible has ultimate control over the appearance and behavior of
decorations and modality. For example, some window managers only support
resizable windows and will always assume the RESIZE style, even if it is
not set. [...]"
And I don't think you can do something about it...
Re: problem in dialog window in linux ?? [message #436206 is a reply to message #436134] |
Wed, 12 May 2004 23:19 |
Daniel Spiewak Messages: 263 Registered: July 2009 |
<html>
<head>
<title></title>
</head>
Actually, the problem is not that GTK <i>doesn't</i> support
non-resizable windows. It's that SWT on GTK doesn't support
non-resizable windows. Look around through some of the native apps in
GTK. You look long enough, you'll find a non-resizable window (I've
found several). The only thing I can think of to do about it is to
edit the native code handling the window creation on GTK and submit a
patch.<br>
<br>
Daniel<br>
<br>
Dima Frunza wrote:
<blockquote cite="midc7shtr$l9h$1@eclipse.org" type="cite">achal
rastogi wrote:
<br>
<blockquote type="cite">hi guys
<br>
<br>
<br>
it
<br>
<br>
thanks in advance..
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
is visible has ultimate control over the appearance and behavior of
support resizable windows and will always assume the RESIZE style, even
if it is not set. [...]"
<br>
<br>
<br>
</blockquote>
</body>
</html>
Re: problem in dialog window in linux ?? [message #436222 is a reply to message #436206] |
Thu, 13 May 2004 13:16 |
Steve Northover Messages: 1636 Registered: July 2009 |
------=_NextPart_000_0009_01C438CA.FDCF0A50
Content-Type: text/plain;
charset="iso-8859-1"
This was fixed a while back. The problem was that the window manger was =
changed and more code was needed to convince it to honour the hints. =
This same code on Solaris under MWM caused a bunch of trouble. =
Basically, we work fine, them either GTK or the window manger changes, =
then we don't work and fix it, then GTK or the window manager changes, =
then ...
"Daniel Spiewak" <djspiewak@hotpop.com> wrote in message =
news:c7ub44$1m9$1@eclipse.org...
Actually, the problem is not that GTK doesn't support non-resizable =
windows. It's that SWT on GTK doesn't support non-resizable windows. =
Look around through some of the native apps in GTK. You look long =
enough, you'll find a non-resizable window (I've found several). The =
only thing I can think of to do about it is to edit the native code =
handling the window creation on GTK and submit a patch.
Daniel
Dima Frunza wrote:=20
achal rastogi wrote:=20
hi guys=20
here is a code snippet for creating dialog shell ..it works fine =
on=20
windows , means it doesnt show maximize,minimize button and you =
cant=20
resize it but on linux it shows maximize,minimize and i can even =
resize it=20
.can anyone suggest me some other way or tell me the problem in =
this ,=20
thanks in advance..=20
final Shell parent =3D getParent();=20
shell =3D new Shell(parent, SWT.DIALOG_TRIM | =
SWT.APPLICATION_MODAL);=20
Excerpt from the Shell's Javadoc:=20
"Note: The styles supported by this class (Shell) must be treated as =
HINTs, since the window manager for the desktop on which the instance is =
visible has ultimate control over the appearance and behavior of =
decorations and modality. For example, some window managers only support =
resizable windows and will always assume the RESIZE style, even if it is =
not set. [...]"=20
And I don't think you can do something about it...=20
Content-Type: text/html;
<HTML><HEAD><TITLE></TITLE>
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>This was fixed a while back. The =
problem was=20
that the window manger was changed and more code was needed to convince =
it to=20
honour the hints. This same code on Solaris under MWM caused a =
bunch of=20
trouble. Basically, we work fine, them either GTK or the window =
manger=20
changes, then we don't work and fix it, then GTK or the window manager =
changes,=20
then ...</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"Daniel Spiewak" <<A=20
href=3D"mailto:djspiewak@hotpop.com">djspiewak@hotpop.com</A>> =
wrote in=20
message <A=20
href=3D"news:c7ub44$1m9$1@eclipse.org">news:c7ub44$1m9$1@eclipse.org</A>.=
...</DIV>Actually,=20
the problem is not that GTK <I>doesn't</I> support non-resizable=20
windows. It's that SWT on GTK doesn't support non-resizable=20
windows. Look around through some of the native apps in =
GTK. You=20
look long enough, you'll find a non-resizable window (I've found=20
several). The only thing I can think of to do about it is to =
edit the=20
native code handling the window creation on GTK and submit a=20
patch.<BR><BR>Daniel<BR><BR>Dima Frunza wrote:=20
<BLOCKQUOTE cite=3Dmidc7shtr$l9h$1@eclipse.org type=3D"cite">achal =
rastogi=20
wrote: <BR>
<BLOCKQUOTE type=3D"cite">hi guys <BR>here is a code snippet for =
creating=20
dialog shell ..it works fine on <BR>windows , means it doesnt show =
maximize,minimize button and you cant <BR>resize it but on linux =
it shows=20
maximize,minimize and i can even resize it <BR>.can anyone suggest =
me some=20
other way or tell me the problem in this , <BR>thanks in advance.. =
<BR><BR> final Shell parent =3D getParent(); <BR> shell =
=3D new=20
Shell(parent, SWT.DIALOG_TRIM | SWT.APPLICATION_MODAL);=20
<BR><BR></BLOCKQUOTE><BR>Excerpt from the Shell's Javadoc: =
<BR><BR>"Note:=20
The styles supported by this class (Shell) must be treated as HINTs, =
since=20
the window manager for the desktop on which the instance is visible =
has=20
ultimate control over the appearance and behavior of decorations and =
modality. For example, some window managers only support resizable =
windows=20
and will always assume the RESIZE style, even if it is not set. =
[...]"=20
<BR><BR>And I don't think you can do something about it...=20
<BR></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0009_01C438CA.FDCF0A50--
Current Time: Thu Apr 18 06:41:42 GMT 2024
Powered by FUDForum. Page generated in 0.02650 seconds
