Exchanging data between plugins [message #436017] |
Mon, 29 August 2005 18:04  |
Hi everybody,
i know this has been asked before, but i simple donŽt get the point how to
do it and havenŽt found any example code.
I want ot exchange data between two plugins.
Plugin No.1 is doing a search on a database.
Plugin No.2 should use this data for further processing.
How can i transfer the data from Plugin No.1 to Plugin No.2 ?
IŽve read that i might have to define extension points.
Can anybody please give me a little bit more of a description on how to
achieve this?
Any examples, maybe?
IŽm pretty confused at the moment and have looked for ages on how to
achieve something like this.
Greetings
Thomas
Re: Exchanging data between plugins [message #436176 is a reply to message #436017] |
Thu, 01 September 2005 12:16  |
Thomas wrote:
> Hi everybody,
> to do it and havenŽt found any example code.
> achieve this?
> Greetings
> Thomas
You don't really need to define extension points for this.
You can, for example, have a DBManager class on one side and a
DBResultPresentation class on the other side.
They know each other by using a singleton on the DBManager side.
private static final DBManager instance = new DBManager();
static DBManager getSingleton() {
return instance;
And DBManager.getSingleton() in the DBResultPresentation class.
You would need to use extension if for example, the number and type of
DB in the application is defined through the use of a plugin. In this
case you would have to first discover the DB available in the current
context and then get a reference to them.
Hth,
Cedric
FUDForum. Page generated in 0.03919 seconds
