Home » Eclipse Projects » Rich Client Platform (RCP) » howto "overwrite" the close() method of the Workbench
howto "overwrite" the close() method of the Workbench [message #435999] Mon, 29 August 2005 11:57 Go to next message
Andreas Pakulat is currently offline Andreas PakulatFriend
I'd like to find a way to reject the workbench closing under certain
circuumstances. In particular I have an editor which has a button in it,
that calls IWorkbench.close() when clicked. But before the closing
can actually happen, I have to read some stuff from the editor input and
send that over a network connection to a server. Then depending on the
answer from the server the closing needs to be intercepted or not.
I did not yet try, but from the docs it seems that using a
WindowListener and listen to the close-Event of the Editor-Window might
be a proper way, or is there another way to do this?
Andreas
Re: howto "overwrite" the close() method of the Workbench [message #436050 is a reply to message #435999] Tue, 30 August 2005 11:13 Go to previous message
Alex Blewitt is currently offline Alex BlewittFriend
Have a look at the WorkbenchAdvisor class (assuming that you're dealing with a plugin that uses one).
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/api/org/eclipse/ui/progress/Workb enchJob.html
There's a method called 'preShutdown' that returns true if the workbench is OK to be closed:
http://help.eclipse.org/help31/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/ui/application/WorkbenchAdvi sor.html#preShutdown()
That may not be much use if you're not customising your own RCP though ...
Previous Topic:Is RCP a real subset of Platform ?
Next Topic:Show View menu in RCP
Current Time: Sun Dec 08 09:51:47 GMT 2024
Powered by FUDForum. Page generated in 0.03258 seconds
