Re: JFace Action causing error [message #435922 is a reply to message #435914] |
Fri, 07 May 2004 14:38 |
Originally posted by: not.all.com
You probably need to include the osgi.jar. That's a change from 2.x -> 3.x.
Alan wrote:
> Hi. I'm trying to complete a tutorial that can be found at:
> http://www-106.ibm.com/developerworks/opensource/library/os- ecgui3/
> I'm running Eclipse Version: 3.0.0 Build id: 200403261517 and I've tried
> it under Windows and Linux. When I press the Exit button I receive the
> following:
> Any ideas where I'm going wrong?
> java.lang.NoClassDefFoundError: org/osgi/framework/InvalidSyntaxException
> at org.eclipse.core.runtime.Platform.getDebugOption(Platform.ja va:349)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:502)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:435)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:769)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2578)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2256)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:670 )
> at org.eclipse.jface.window.Window.open(Window.java:650)
> at Hello.main(Hello.java:60)
FUDForum. Page generated in 0.04451 seconds
