Home » Eclipse Projects » Rich Client Platform (RCP) » Dynamic help preferences
Dynamic help preferences [message #435812] Wed, 24 August 2005 09:58 Go to next message
Dirk Segelhorst is currently offline Dirk SegelhorstFriend
the default behavior in Eclipse 3.1 for showing the help content is to
use the new dynamic help view. How can I set the preferences for the
help programatically in order to get the old behavior (<=Eclipse 3.0) back?
Thanks for any help,
Dirk
Re: Dynamic help preferences [message #435821 is a reply to message #435812] Wed, 24 August 2005 14:39 Go to previous messageGo to next message
Alex Blewitt is currently offline Alex BlewittFriend
Help -> Help Contents brings up the help system. You can bind whatever key stroke(s) you want to using the Window -> Preferences menu and using 'Modify'. The category is 'Help' and the name is 'Help Contents'.
You can then bind it to F1 or whatever you want.
Re: Dynamic help preferences [message #435852 is a reply to message #435821] Thu, 25 August 2005 04:32 Go to previous message
but this is not what I was searching for. I searched for some API to set
the preferences programatically. I didn't want to set the key bindings!
Previous Topic:Newbie to RCP..
Next Topic:How can I use ANT outside Eclipse to make a deployable RCP app?
Current Time: Sun Dec 08 03:13:48 GMT 2024
Powered by FUDForum. Page generated in 0.02832 seconds
