Home » Eclipse Projects » Rich Client Platform (RCP) » Problem with JBoss 3.2.3, Web Start and RCP
Problem with JBoss 3.2.3, Web Start and RCP [message #435772] Tue, 23 August 2005 09:18 Go to next message
Originally posted by: avier5.hotmail.com
Hi all,
Your help is needed...
I have wrote a plugin and tried to call it from Web Start . I use JBoss
3.2.3 as my server.
The downloads from Web Start work fine but now before the plugin show
itself I get the following exception:
*************** Start Here ****************************
!SESSION 2005-08-23 16:02:38.109
eclipse.buildId=unknown
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=iw_IL
!ENTRY org.eclipse.osgi 2005-08-23 16:02:38.703
!MESSAGE Error installing bundle:
reference:file:DMshared/RMorg.eclipse.osgi_3.1.0.jar/
!STACK 0
org.osgi.framework.BundleException: Bundle "system.bundle" version "3.1.0"
has already been installed from: System Bundle
org.eclipse.osgi.framework.internal.core.Framework.createAnd VerifyBundle(Framework.java:557)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:822)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:737)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:788)
************* End Here *************************
Of course that I put in the server all my plugin's required plugins.
I don't know what to do more.... Need Help
Any ideas ?
Avier
Re: Problem with JBoss 3.2.3, Web Start and RCP [message #435782 is a reply to message #435772] Tue, 23 August 2005 20:46 Go to previous messageGo to next message
The error about osgi is a known bug that has been fixed in tomorrow's
3.1.1 build.
PaScaL
Avier5 wrote:
> Hi all,
> 3.2.3 as my server.
> !STACK 0
> "3.1.0" has already been installed from: System Bundle
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> Any ideas ?
> Avier
Re: Problem with JBoss 3.2.3, Web Start and RCP [message #435807 is a reply to message #435782] Wed, 24 August 2005 02:24 Go to previous messageGo to next message
First of all : THANK YOU !!! I am looking forward for this Eclipse release.
Second:
Can you explain what have caused this exception?
Thank you again....
Re: Problem with JBoss 3.2.3, Web Start and RCP [message #435850 is a reply to message #435807] Wed, 24 August 2005 22:23 Go to previous messageGo to next message
The exception was caused by the code that discover the bundles to
install. It was not removing osgi from the set of things to install
therefore it was causing this exception however, it was harmless since
the app could still start.
PaScaL
> Second:
> Thank you again....
Re: Problem with JBoss 3.2.3, Web Start and RCP [message #435980 is a reply to message #435782] Sun, 28 August 2005 02:33 Go to previous messageGo to next message
Originally posted by: avier5.gmail.com
Hi Pascal,
I need a way to work around this bug. Can you give me any idea how to do
it OR please tell me when and where I can get build 3.1.1 of Eclipse's sdk
Thank you
Avier
Re: Problem with JBoss 3.2.3, Web Start and RCP [message #435982 is a reply to message #435980] Sun, 28 August 2005 08:59 Go to previous messageGo to next message
avier wrote:
> Hi Pascal,
> sdk ?
> Thank you Avier
I was getting the same error until I added the org.eclipse.update.configurator plugin to my 'wrapping' feature. Perhaps doing
that will fix your problem also.
I am using Eclipse 3.1.0.
Re: Problem with JBoss 3.2.3, Web Start and RCP [message #435991 is a reply to message #435982] Mon, 29 August 2005 04:32 Go to previous messageGo to next message
ted stockwell wrote:
> avier wrote:
>> Hi Pascal,
>> sdk ?
>> Thank you Avier
doing
I am doing exactly as it is written in the eclipse help undar-"Deploying
eclipse based application with Java Web Start" - and I can't go over step
2 with export of the feature.
What did I foreget ?
Avier
Re: Problem with JBoss 3.2.3, Web Start and RCP --- ????? ANYONE?? [message #436009 is a reply to message #435991] Mon, 29 August 2005 12:23 Go to previous messageGo to next message
Is anyone successed in deploying Eclipse 3.1 RCP application in JBoss and
run it with WebStart ?
A detailed example will be very useful and appreciated.
Avier
Re: Problem with JBoss 3.2.3, Web Start and RCP --- ????? ANYONE?? [message #436235 is a reply to message #436009] Fri, 02 September 2005 07:45 Go to previous message
http://download.eclipse.org/eclipse/downloads/drops/M2005083 1-1200/index.php
> and run it with WebStart ?
> Avier
Previous Topic:RCP WebStart problem - ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
Next Topic:Workbench saved state location
Current Time: Fri Nov 07 14:46:58 EST 2025
Powered by FUDForum. Page generated in 0.10663 seconds
