Home » Eclipse Projects » Standard Widget Toolkit (SWT) » A question about display
A question about display [message #435686] Sat, 01 May 2004 22:30 Go to next message
Originally posted by: sarahjws.hotmail.com
I am a Eclipse beginner. I am working on a library Management System.
There is a main menu and when the menu item is selected, a new dialog
should be displayed. For example, when I selects "Add Borrower", a dialog
appears and I can input some informaiton about the new borrower such as
name and ID. My question is, so far I got the dialog, but nothing appears
in this dialog. The following is my program:
public class MenuSample {
MenuSample window = new MenuSample();
window.open();
public void open() {
final Display display = new Display();
final Shell shell = new Shell();
shell.setText("Library Management System");
Menu menu=new Menu(shell,SWT.BAR);
shell.setMenuBar(menu);
MenuItem bomenu=new MenuItem(menu,SWT.CASCADE);
bomenu.setText("Borrower");
Menu filemenu=new Menu(bomenu);
bomenu.setMenu(filemenu);
MenuItem addBoItem=new MenuItem(filemenu,SWT.NONE);
addBoItem.setText("Add Borrower");
MenuItem updBoItem=new MenuItem(filemenu,SWT.PUSH);
updBoItem.setText("Update Borrower");
MenuItem seperator=new MenuItem(filemenu,SWT.SEPARATOR);
MenuItem quitItem=new MenuItem(filemenu,SWT.PUSH);
quitItem.setText("Exit");
addBoItem.addListener(SWT.Selection,new Listener(){
public void handleEvent(Event e){
BorrowerFrame bf=new BorrowerFrame(shell);
bf.open();
public class BorrowerFrame extends Dialog {
Object result;
public BorrowerFrame(Shell parent, int style) {
super (parent, style);
public BorrowerFrame(Shell parent) {
this (parent, 0);
public Object open () {
Shell parent = getParent();
Shell dialog = new Shell(parent, SWT.DIALOG_TRIM |
SWT.APPLICATION_MODAL);
dialog.setText("Add Borrower");
Label label1=new Label(dialog,SWT.NONE);
label1.setText("Last Name");
Text text1=new Text(dialog,SWT.BORDER);
text1.setTextLimit(20);
dialog.open();
return result;
I know I should add something like layout manager, but I think that is not
the key for this question.
Anyone can give me suggestion? This is my final project. Your help will be
greatly appreciated!
sarah
Re: A question about display [message #435687 is a reply to message #435686] Sun, 02 May 2004 00:16 Go to previous messageGo to next message
Daniel Spiewak is currently offline Daniel SpiewakFriend
You do need to add a layout manager. Unlike Swing, in SWT there is no
default layout manager.
Daniel
> public static void main(String[] args) {
> window.open();
> bf.open();
> Object result;
> this (parent, 0);
> dialog.open();
> return result;
>sarah
Re: A question about display [message #436085 is a reply to message #435686] Tue, 11 May 2004 11:44 Go to previous message
Originally posted by: "prenom.,nom".sextant.thomson-csf.com
I've got the same problem. Did you find the solution?
> window.open();
> bf.open();
> Object result;
> this (parent, 0);
> dialog.open();
> return result;
> sarah
Previous Topic:Problem with FileDialog
Next Topic:Problem with SWT_AWT
Current Time: Tue Apr 16 07:30:53 GMT 2024
Powered by FUDForum. Page generated in 0.05340 seconds
