Home » Eclipse Projects » Rich Client Platform (RCP) » How to get the text under the mouse in the org.eclipse.swt.widgets.Text
How to get the text under the mouse in the org.eclipse.swt.widgets.Text [message #435657] Mon, 22 August 2005 01:25 Go to next message
Originally posted by: yewb.archean.net
In eclipse's java editor, when mouse is over a text, such as a method, so,
a hoverhelp will be popped up.
But how can I get the text under the mouse in my application?
Can I use org.eclipse.swt.widgets.Text to do it?
Re: How to get the text under the mouse in the org.eclipse.swt.widgets.Text [message #435713 is a reply to message #435657] Mon, 22 August 2005 13:36 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
This is done much easier with a StyledText since it provides a
getOffsetAtLocation(Point) API that answers the text offset for a given x,y
coordinate (in this case you would provide the x,y from the trigger
MouseHover event). Once you have the text index then you can use
getText(int,int) to get the text surrounding this point.
Grant
"yewb" <yewb@archean.net> wrote in message
news:deb9if$cdv$1@news.eclipse.org...
Re: How to get the text under the mouse in the org.eclipse.swt.widgets.Text [message #435769 is a reply to message #435713] Tue, 23 August 2005 12:24 Go to previous message
Thank you
"Grant Gayed" <grant_gayed@ca.ibm.com> д
Previous Topic:how to prevent user to transfer a view from a folder to another
Next Topic:RCP WebStart problems
Current Time: Sat Dec 14 17:46:42 GMT 2024
Powered by FUDForum. Page generated in 0.03498 seconds
