Re: Building RCP Applications [message #435370 is a reply to message #435368] |
Tue, 16 August 2005 13:59 |
Originally posted by: jordan.day.21csi.com
Well, I don't know what other errors you're experiencing, but based on the
one you listed below, I'm wondering if you have configured the product
completely. When you open your XXXX.product file, go to the configuration
page, and make sure to click "Add Required Plug-ins"... this should include
all the plugins that your plugin uses.
Jordan
"Marcus Olk" <molk@comosoft.de> wrote in message
news:ddsq8p$a9a$1@news.eclipse.org...
> Hi.
> This is not the first time me and other RCP developers have to
> ask this question. Due to the fact that I'm currently completely
> pissed off by the fact that obviously the whole plugin architecture
> is lacking a decent build process, I'd like to know how you guys
> manage to build a RCP based product?!
> So: where can I find a proper documentation on how to build a
> RCP based application?!
> The 3.1 export wizard triggered by the 'Product Configuration Editor'
> simply doesn't work, well sometimes it does, sometimes it doesn't.
> Errors reported by the export wizard (logs.zip) are next to useless,
> because one has no clue how to solve them. Here's an example of
> one of the log files:
> 1. ERROR in C:\development\projects\...\XXX.java
> (at line 18)
> import org.eclipse.jface.resource.ColorRegistry;
> The import org.eclipse.jface cannot be resolved
> Interesting. And why is it possible to run the product from within
> the IDE? Shouldn't this give me the same error?! It doesn't.
> The IDE compiles the same plugin and the run configuration used to
> run the product launches the application without any errors.
> I've got a really bad feeling that I still don't understand the
> black magic needed to applied to determine all required plugins.
> This build process sucks.
> Sorry for moaning, but this issue consumed way too much time
> since we decided to choose the RCP framework for building our
> applications; time that's wasted taking the domain functionality
> into account we have to implement. After all we spent 70% struggling
> with the RCP framework until now.
> RCP - a bad decision after all, but we spent so much time on it that we
> have no choice but to continue to find further workarounds to get a
> product shipped some day - hopefully.
> Marcus
Re: Building RCP Applications [message #435374 is a reply to message #435371] |
Tue, 16 August 2005 15:54 |
Originally posted by: wegener.cboenospam.com
Marcus Olk wrote:
> Jordan,
> thanks for you reply.
> Sure I did. And the interesting fact is that the same product
> configuration exports fine on a different machine without errors.
> I have no clue how to debug what goes wrong on the particular
> machine. It's the same Eclipse Version (3.1), the same OS (Windows XP)
> and its the same source code snapshot checked out from the repository.
> That's my point: if it exports - fine. But if not you're left alone
> in the dark - there's no way to debug a failing build/export process.
> "Here's your error logs - enjoy guessing what went wrong..."
> What's left is trial'n'error and that's very bad.
> Marcus
Take a look at this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=101966
Is references deploying plugins and not RCP applications, but still might
be applicable.
Re: Building RCP Applications [message #435377 is a reply to message #435371] |
Wed, 17 August 2005 06:31 |
I had a similar problem - and also spend a big time on it.
In my case we had imported one or more of the RCP plugins into
workspace as project binaries with linked content and on one or
more of these plugins there where config errors (no idea where they
came from) that reduced the package visibility to other
plugins. As the plugins in workspace take precedence over the
configured plugins at runtime these errors surfaced and gave
us a real hard time. when i removed these plugin-projects
from workspace everything went fine... since then I look
very carefully at the import options when importing a
plugin into workspace.
I did not cross check this issue thoroughly, basically because
I was happy that everything was up and running again.
I am also very confused sometimes about the side-effects that
the product configuration and its wizards have - I feel their
activity is not really consistent to the in-IDE compilation
process. This is mainly because of differences in the actual
classpath when in IDE and while and after exporting...
are there any guides on this available or do I have to
employ somebody to dig into the sources ;-)
Maybe this helps
Greets
Jens
FUDForum. Page generated in 0.04035 seconds
