Home » Eclipse Projects » Rich Client Platform (RCP) » setting the default PreferencePage in the PreferenceDialog
setting the default PreferencePage in the PreferenceDialog [message #435359] Mon, 15 August 2005 23:17 Go to next message
Geoff Draper is currently offline Geoff DraperFriend
Member
Does anyone know of a way to specify programmatically which Preference =
Page should be displayed first when the main Preference Dialog is opened=
It defaults to the one at the op of the list of Preferences Pages, but i=
s =
there a way to specify a different initial Preference Page?
It looks like it should be the =
PreferenceDialog.setCurrentPage(IPreferencePage currentPage) method, but=
how do I get a reference to the global PreferenceDialog object?
Geoff
Re: setting the default PreferencePage in the PreferenceDialog [message #436003 is a reply to message #435359] Mon, 29 August 2005 14:50 Go to previous message
Member
Here's one way I've found to do it:
PreferenceDialog dialog =3D PreferencesUtil.createPreferenceDialogOn(
null, ID_OF_DESIRED_PREFERENCE_PAGE, null, null);
dialog.open();
....where ID_OF_DESIRED_PREFERENCES_PAGE is the ID of the PreferencePage =
you want to open, as specified in the org.eclipse.ui.preferencePages =
extension point in plugin.xml. Also, if you have a convenient way of =
obtaining the correct Shell object (via getShell() for example) you can =
pass the Shell as the first argument of the createPreferenceDialogOn =
method. If not, passing null seems to work too.
On Mon, 15 Aug 2005 17:17:03 -0600, Geoff Draper <thirstynellan@yahoo.co=
m> =
wrote:
> Does anyone know of a way to specify programmatically which Preference=
> Page should be displayed first when the main Preference Dialog is =
> opened? It defaults to the one at the op of the list of Preferences =
> Pages, but is there a way to specify a different initial Preference Pa=
ge?
> PreferenceDialog.setCurrentPage(IPreferencePage currentPage) method, b=
ut =
> Geoff
Previous Topic:Providing context help
Next Topic:Automated GUI-Tests: Abbot? The Eclipse Test Framework?
Current Time: Mon Dec 09 07:26:57 GMT 2024
Powered by FUDForum. Page generated in 0.04685 seconds
