Home » Modeling » EMF » EStructuralFeature.isNullable()
EStructuralFeature.isNullable() [message #431283] Tue, 07 July 2009 13:49 Go to next message
Sven Efftinge is currently offline Sven EfftingeFriend
how can I find out whether a certain feature can be set to null?
For example if I have a feature of type EInt I get a classcastexception,
because under the hood the code trys to autobox null to an int.
Are there any flags, which could give me a hint?
Sven
Re: EStructuralFeature.isNullable() [message #431284 is a reply to message #431283] Tue, 07 July 2009 14:06 Go to previous messageGo to next message
Sven,
Comments below.
Sven Efftinge wrote:
Perhaps you should consider unsetting the feature, i.e., eUnset(feature)
rather eSet(feature, null). Certainly null isn't going to be valid for
an isMany feature, nor will it be valid for a single-valued feature if
EDataType.getInstanceClass().isPrimitive() is true because null is not
in the value space for primitives. There's also
EClassifier.getDefaultValue() which is null except for primitives.
> classcastexception, because under the hood the code trys to autobox
> null to an int.
Maybe I should ask specifically what you're trying to do because eUnset
might be better, or setting to the feature's type's default value might
be better, but there's a subtle difference of course because an
unsettable feature will be set after you call eSet...
> Cheers,
> Sven
Ed Merks
Re: EStructuralFeature.isNullable() [message #431285 is a reply to message #431284] Tue, 07 July 2009 14:28 Go to previous message
Hi Ed,
"EDataType.getInstanceClass().isPrimitive()" is what I was asking for.
I was just stumbling over a bug in Xtext
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=280873) and was curious
about how to find this out reflectively.
Sven
Ed Merks schrieb:
> Sven,
> Comments below.
>> null to an int.
>> Cheers,
>> Sven
Previous Topic:[TENEO] Illegal attempt to associate a collection with two open sessions
Next Topic:EditingDomainActionBarContributor#init(IActionBars)
Current Time: Tue Apr 16 14:44:33 GMT 2024
Powered by FUDForum. Page generated in 0.30569 seconds
