"run as eclipse application" starts always old plugin [message #425752] |
Sun, 07 December 2008 21:18 |
Originally posted by: angelina.velinska.tu-harburg.de
hello,
I generated a model, edit and editor SampleData. after launching a new
instance of eclipse, when i try to 'run as eclipse application' the
newly created plugin SampleData, i always receive opened my 'old'
library example.
i am using eclipse 3.4.1. The problem is that i always get opened the
first plugin (library example) that i have made, even if the project
files containing the library model,edit and editor are already deleted
from the workspace.
Thank you for the advice,
Angelina
Re: "run as eclipse application" starts always old plugin [message #425756 is a reply to message #425752] |
Sun, 07 December 2008 23:50 |
Ed Merks Messages: 33140 Registered: July 2009 |
Angelina,
Comments below.
Angelina Velinska wrote:
> hello,
> library example.
How can you tell it's doing that? Somewhere in the launcher you can
tell it to always clear the configuration area when launching, so that
might help.
> from the workspace.
> Angelina
Ed Merks
FUDForum. Page generated in 0.02844 seconds
