Home » Modeling » EMF » Metamodel registered multiple times
Metamodel registered multiple times [message #425733] Fri, 05 December 2008 16:22 Go to next message
Enrico Schnepel is currently offline Enrico SchnepelFriend
I am switching from Eclipse 3.3 to Eclipse 3.4 and have a problem with some
referenced eclipse-internal metamodels (gmftool/gmfgraph/mappings) which
seems to be registered multiple times. One is the generated one and the
other the dynamic one. I have also switched to the new oAW 4.3. As the
error comes out of the EmfRegistryMetaModel this group is the first try.
At first I am getting a lot of warnings saying that a named type is found
multiple times. Lateron I am getting a CastException that a dynamic type is
incompatible to the generated one. With Eclipse 3.3 and oAW 4.2 everything
worked as expected so something must have been changed here.
Any hints are greatly appreciated.
Enrico
Re: Metamodel registered multiple times [message #425740 is a reply to message #425733] Fri, 05 December 2008 19:02 Go to previous message
Enrico,
Comments below.
Enrico Schnepel wrote:
> Hello,
It's best to ask using the oAW forum. I can only answer questions about
the basic behavior of the core frameworks.
I'd be concerned to find out that specialized frameworks are altering
the contents of EPackage.Registry.INSTANCE directly; it's supposed to be
populated purely using the extensions points provided by the core...
> Enrico
Previous Topic:Trying to reference an interface from an EClass
Next Topic:Custom serialization
Current Time: Tue Feb 18 03:46:37 GMT 2020
Powered by FUDForum. Page generated in 0.05080 seconds
