Re: How to obtain an EAttributes property name? [message #423587 is a reply to message #423579] |
Thu, 02 October 2008 15:46  |
Ed Merks Messages: 31700 Registered: July 2009 |
Morten,
Comments below.
Morten MacFly wrote:
> Dear all,
> let's assume I have an Editor generated out of an Ecore model with
> several parameters (EAttributes).
> Within a method I obtain an EAttribute of a specific type. I would like
> to present the EAttribute's name to the user. Hence if I use the
> EAttribute.getName() method I only get the "models" EAttribute name
> (like "myParam") but not the representation as e.g. in the generated
> PropertySheet of the editor.
> I realise that this is related to the EObject's PropertyDescriptors and
> what I am looking for is what's e.g. in the
> "_UI_[ObjectType]_[Feature]_feature" constant in the plugin.properties
> file of the object providers (e.g. [ObjectType]ItemProvider). I just
> don't know how to access this "string" given an EAttribute and the
> related EObject.
If you know there is a property descriptor for it, you could adapt the
owner object to IItemPropertySource (AdapteFactoryContentProvider
supports that), use getPropertyDescriptor with the feature object as the
ID, and then call getDisplayName.
> An help?!
> With regards, Morten.
Ed Merks
FUDForum. Page generated in 0.02358 seconds
