Home » Modeling » EMF » Automatically loading "child" resources when "parent" resource is loaded
Automatically loading "child" resources when "parent" resource is loaded [message #422898] Thu, 18 September 2008 10:54 Go to next message
Originally posted by: twominutehate.joinpoint.org
in my Metamodel Class A has a transient, multi-valued, containment
reference "children" to Class B.
"A" and each instance of "B" are saved in seperate Resources. When A's
resource is loaded, I want to transparently load all "B" resources
aswell. How many children "A" has is determined by the application by
looking for "B"-resources in the corresponding directory.
As the reference to B is transient, I can't take advantage of EMF proxy
resolving/demand-loading facility.
My first idea was to implement a ResourceSetListener, that returns a
Trigger when the TransactionalEditingDomain notifies me about resource
state chages. The trigger would have been responsible for loading all
related "B"-resources and add their contents to "A.children".
But I've noticed, that the ResourceChangeListener is not always called.
When the resource for an "A" instance is demand-loaded in a read-only
transaction for example, the ResourceSetListener doesn't receive the
corresponding notification.
Is this expected behavior?
Another way would be to add an Adapter to A's resources. When it
detects, that A's "loaded" feature has been set, it schedules an Eclipse
Job, that does essentially the same as the aforementioned trigger.
Could anybody tell me whether there's another, perhaps more preferable
way to do what I want?
Cheers!
Re: Automatically loading "child" resources when "parent" resource is loaded [message #422906 is a reply to message #422898] Thu, 18 September 2008 13:32 Go to previous message
Originally posted by: cdamus.zeligsoft.com
Hi, Ömer,
See some replies in-line, below.
HTH,
Christian
Ömer Yildiz wrote:
> Hello,
Why should it be transient? It sounds like your application depends on
these associations of As to Bs, so perhaps it should be persistent.
Transient containment sounds to me like asking for trouble ...
Yes, it is. The transaction's data-integrity mechanisms (triggers and
validation) are only invoked by read/write transactions, as their
purpose is to safeguard the resource set when changes are performed. In
this regard, the loading of resources in a read-only context (by proxy
resolution or otherwise) is not considered as a change to the state of
the data. It is only revealing more data that, conceptually, already
exists.
Except that, in the case of a read-only transaction, your modification
of the As associated with the Bs that the adapter loads would bomb with
an IllegalStateException on the absence of a read/write transaction.
Why not use cross-resource containment? This is what it's for. It just
seems like make-work to externally implement a lazy-loading mechanism
that EMF already provides.
> Cheers!
Previous Topic:Model instance transformation framework
Next Topic:Forcing EMF code generation for EPackage that contain sub-EPackage only
Current Time: Tue Jan 19 13:23:03 GMT 2021
Powered by FUDForum. Page generated in 0.02050 seconds
