Re: [CDO] CDOStore - Question [message #422509 is a reply to message #422505] |
Mon, 08 September 2008 07:16 |
Hi Simon,
At a first glance it looks like a bug that it is missing in CDOStore.set().
I only wonder why no test has caught this...
Do you have an example of misbehaviour?
Cheers
/Eike
Simon McDuff schrieb:
> Hi Eike,
> I noticed in CDOStore that:
> - When CDOStore.add is called we convert the new value by calling
> convertObjectToID.
> - When we attach an object to view we will call convertObjectToID for every
> attributes.
> - When CDOStore.set is called... we do not call convertObjectToID.
> I know at the end we will call provideCDOID... but do we have a reason why
> we do not call convertObjectToID ?
> Thank you
> Simon
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] CDOStore - Question [message #422529 is a reply to message #422528] |
Mon, 08 September 2008 16:08 |
> Testcase will not get that since the behavior will be as expected since in
> commit process we convert it in CDOID.
> The only problem it will occured is if the refer object is already
> persisted.... we cannot garbage collect that object :-(
> I will add a testcase and a bugzilla entry for that. Ok ?
Yes, that's fine.
Thx
/Eike
> "Eike Stepper" <stepper@esc-net.de> a écrit dans le message de news:
> ga2jhf$il6$3@build.eclipse.org...
>> Hi Simon,
>> CDOStore.set().
>> Cheers
>> /Eike
>>> Hi Eike,
>>> convertObjectToID.
>>> every attributes.
>>> why we do not call convertObjectToID ?
>>> Thank you
>>> Simon
Cheers
/Eike
FUDForum. Page generated in 0.03239 seconds
