How to Drag a node from a tree view to EMF editor? [message #418284] |
Wed, 09 April 2008 23:30 |
Originally posted by: hufangjian31.hotmail.com
I have an application like the "library" example, so you can creat a
library that has kinds of books. Let's say we have creat a library which
has 3 books and we save this file. I have created my own tree view to
diaplay the content of this "library", I mean, you can see how many books
are there in this library from this view.
Now if I want to drag a "book" from this tree view and drop it to the EMF
editor, I hope I can creat a new "book" item to the EMF editor.
what can I do to achieve that?//or is there any article or tutorial about
this?
any advice will be welcome.
Thanks in advance!
Best Regards
HU Fangjian
Re: How to Drag a node from a tree view to EMF editor? [message #418285 is a reply to message #418284] |
Thu, 10 April 2008 00:39 |
Ed Merks Messages: 33113 Registered: July 2009 |
Drag and drop support is hooked up like this in the generated editor:
viewer.addDragSupport(dndOperations, transfers, new
ViewerDragAdapter(viewer));
viewer.addDropSupport(dndOperations, transfers, new
EditingDomainViewerDropAdapter(editingDomain, viewer));
You'll need to investigate how that works to do something similar...
Fangjian wrote:
> which has 3 books and we save this file. I have created my own tree
> view to diaplay the content of this "library", I mean, you can see how
> many books are there in this library from this view.
> EMF editor, I hope I can creat a new "book" item to the EMF editor.
> about this? any advice will be welcome.
> Thanks in advance!
> Best Regards
> HU Fangjian
Ed Merks
Re: How to Drag a node from a tree view to EMF editor? [message #418296 is a reply to message #418285] |
Thu, 10 April 2008 23:19 |
Thanks for your advice.
I know that you can drag a "book" form the outline view and drop it to the
EMF editor. I can drag the "book" from my own tree view but I can not drop
to the editor. Is there any trick about this?
> Fangjian wrote:
>> Thanks in advance!
>> Best Regards
>> HU Fangjian
Re: How to Drag a node from a tree view to EMF editor? [message #418297 is a reply to message #418296] |
Thu, 10 April 2008 23:36 |
Fangjian,
I guess you hooked up a drag source to your view... Did you try setting
breakpoints in the drop adapter to see what happens when you try to drop
into the editor. The debugger is your best friend and it's not a good
idea to neglect one your best friends...
> the EMF editor. I can drag the "book" from my own tree view but I can
> not drop to the editor. Is there any trick about this?
>> Fangjian wrote:
>>> Hi,
>>> how many books are there in this library from this view.
>>> the EMF editor, I hope I can creat a new "book" item to the EMF
>>> editor. what can I do to achieve that?//or is there any article or
>>> tutorial about this? any advice will be welcome.
>>> Thanks in advance!
>>> Best Regards
>>> HU Fangjian
Ed Merks
FUDForum. Page generated in 0.04081 seconds
