Re: Register EdingDomain as an extenion [message #417007 is a reply to message #416991] |
Fri, 22 February 2008 16:44 |
Hi, Charles, Ed,
The main reason why EMF Transaction component took the
extension-point/registry approach to sharing editing domains amongst
multiple applications was to enable declarative associations of these
editing domains with various other facilities.
One example of this is the org.eclipse.emf.transaction.listeners extension
point. There are other uses of the registry that were intended way back
when but have never materialized.
Christian
Ed Merks wrote:
> Charles,
> No. I'm not sure what this would imply. Maybe Christian will
> understand the question better...
> Charles Martin wrote:
>> Is it possible to register a plain-old EditingDomain as an extension
>> point, in the same this can be done with a TransactionalEditingFactory?
>> Thanks
>> Charles
FUDForum. Page generated in 0.03475 seconds
