Home » Modeling » EMF » Creating EMF model from XML schema in Eclipse 3.3
Creating EMF model from XML schema in Eclipse 3.3 [message #416110] |
Fri, 18 January 2008 10:27 |
Originally posted by: karin.schellner.lixto.com
in Eclipse 3.3 we are missing the option to import an EMF model from an XML
schema (there are only model importers for Ecore models and Rose class
models). It was working in Eclipse 3.2 though. Does anyone know if and how
this can be done in Eclipse 3.3?
thanks,
karin.
Re: Creating EMF model from XML schema in Eclipse 3.3 [message #416125 is a reply to message #416116] |
Fri, 18 January 2008 13:55 |
I have the following xsd plugins installed:
org.eclipse.xsd
org.eclipse.xsd.edit
Do I need another one?
thanks,
karin
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag
news:fmq3j5$ihc$2@build.eclipse.org...
> Karin,
> It sounds like you simply didn't install the XSD plugins. If you go to
> "Help->About Eclipse SDK->Plug-in Details..." are the org.eclipse.xsd
> plugins there?
> Karin Schellner wrote:
>> XML schema (there are only model importers for Ecore models and Rose
>> class models). It was working in Eclipse 3.2 though. Does anyone know if
>> and how this can be done in Eclipse 3.3?
>> thanks,
>> karin.
Re: Creating EMF model from XML schema in Eclipse 3.3 [message #416126 is a reply to message #416125] |
Fri, 18 January 2008 14:06 |
Ed Merks Messages: 33140 Registered: July 2009 |
--------------020502050405010002080306
Karin,
You'd also need org.eclipse.xsd.ecore.importer. If you have that too,
maybe they're the wrong version? How did you install them? Try the
following. Go to the Error Log view and clear it (or delete
<workspace>/.metadata/.log which is what the Error log views). Then
shutdown Eclipse and when you run it again, run with -clean -debug.
Then have a close look at the Error log. Look in particular for
messages about org.eclipse.xsd which, if it's been disabled, will
include the reasons why it's disabled...
> org.eclipse.xsd
> thanks,
> karin
>> Karin,
>> plugins there?
>>> Hi,
>>> thanks,
>>> karin.
<html>
<head>
</head>
Karin,<br>
<br>
too, maybe they're the wrong version? How did you install them? Try
the following. Go to the Error Log view and clear it (or delete
Then shutdown Eclipse and when you run it again, run with -clean
-debug. Then have a close look at the Error log. Look in particular
for messages about org.eclipse.xsd which, if it's been disabled, will
include the reasons why it's disabled...<br>
<br>
<br>
<blockquote cite="mid:fmqb4o$91g$1@build.eclipse.org" type="cite">
<pre wrap="">I have the following xsd plugins installed:
org.eclipse.xsd
thanks,
karin
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> schrieb im Newsbeitrag
<a class="moz-txt-link-freetext" href="news:fmq3j5$ihc$2@build.eclipse.org">news:fmq3j5$ihc$2@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Karin,
plugins there?
</pre>
<pre wrap="">Hi,
thanks,
karin.
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------020502050405010002080306--
Ed Merks
Re: Creating EMF model from XML schema in Eclipse 3.3 [message #416141 is a reply to message #416126] |
Fri, 18 January 2008 16:34 |
I have installed the "Eclipse IDE for Java EE Developers" which includes all
EMF staff but does not include the plugin you mentioned:
Do you know with which package this plugin should come as I don't know about
dependencies ...
thanks,
karin.
news:fmqboc$eur$1@build.eclipse.org...
Karin,
shutdown Eclipse and when you run it again, run with -clean -debug. Then
have a close look at the Error log. Look in particular for messages about
org.eclipse.xsd which, if it's been disabled, will include the reasons why
it's disabled...
org.eclipse.xsd
thanks,
karin
Karin,
plugins there?
thanks,
karin.
Re: Creating EMF model from XML schema in Eclipse 3.3 [message #416144 is a reply to message #416141] |
Fri, 18 January 2008 18:10 |
--------------060900070204010000090500
Karin,
I see. You could use the update manager to get it or get is separate
from the XSD downloads site:
http://www.eclipse.org/modeling/mdt/downloads/?project=xsd
Be sure to get a version that goes with your Eclipse version, i.e.,
2.3.x goes with Eclipe 3.3.x, and 2.4 goes with Eclipse 3.4. (You'd
think that XSD to Ecore conversion would be particularly useful in the
EE package; go figure.)
> dependencies ...
> thanks,
> karin.
> Karin,
> it's disabled...
> org.eclipse.xsd
> thanks,
> karin
> Karin,
> plugins there?
> thanks,
> karin.
<html>
<head>
</head>
Karin,<br>
<br>
from the XSD downloads site:<br>
<blockquote><a
href="http://www.eclipse.org/modeling/mdt/downloads/?project=xsd">http://www.eclipse.org/modeling/mdt/downloads/?project=xsd</a><br>
</blockquote>
EE package; go figure.)<br>
<br>
<br>
<blockquote cite="mid:fmqkf6$pdn$1@build.eclipse.org" type="cite">
<pre wrap="">I have installed the "Eclipse IDE for Java EE Developers" which includes all
dependencies ...
thanks,
karin.
<a class="moz-txt-link-freetext" href="news:fmqboc$eur$1@build.eclipse.org">news:fmqboc$eur$1@build.eclipse.org</a>...
Karin,
it's disabled...
org.eclipse.xsd
thanks,
karin
Karin,
plugins there?
thanks,
karin.
</pre>
</blockquote>
<br>
</body>
</html>
--------------060900070204010000090500--
Ed Merks
Re: Creating EMF model from XML schema in Eclipse 3.3 [message #416170 is a reply to message #416144] |
Mon, 21 January 2008 09:46 |
------=_NextPart_000_000A_01C85C1A.DA55A490
charset="iso-8859-1"
Ed,
thanks a lot for this info! It works fine now!
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag =
news:fmqq1r$bb9$1@build.eclipse.org...
Karin,
I see. You could use the update manager to get it or get is separate =
http://www.eclipse.org/modeling/mdt/downloads/?project=3Dxsd
Be sure to get a version that goes with your Eclipse version, i.e., =
2.3.x goes with Eclipe 3.3.x, and 2.4 goes with Eclipse 3.4. (You'd =
think that XSD to Ecore conversion would be particularly useful in the =
Karin Schellner wrote:=20
I have installed the "Eclipse IDE for Java EE Developers" which includes =
all=20
Do you know with which package this plugin should come as I don't know =
about=20
dependencies ...
thanks,
karin.
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag=20
Karin,
You'd also need org.eclipse.xsd.ecore.importer. If you have that too, =
maybe they're the wrong version? How did you install them? Try the=20
following. Go to the Error Log view and clear it (or delete=20
<workspace>/.metadata/.log which is what the Error log views). Then=20
shutdown Eclipse and when you run it again, run with -clean -debug. =
Then=20
have a close look at the Error log. Look in particular for messages =
about=20
org.eclipse.xsd which, if it's been disabled, will include the reasons =
why=20
it's disabled...
org.eclipse.xsd
thanks,
karin
Karin,
plugins there?
thanks,
karin.
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3243" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>thanks a lot for this info! It =
works fine=20
now!</FONT></DIV>
<DIV> </DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
schrieb im Newsbeitrag <A=20
href=3D"news:fmqq1r$bb9$1@build.eclipse.org">news:fmqq1r$bb9$1@build.ecli=
pse.org</A>...</DIV>Karin,<BR><BR>I=20
see. You could use the update manager to get it or get is =
separate from=20
the XSD downloads site:<BR>
<BLOCKQUOTE><A=20
href=3D" http://www.eclipse.org/modeling/mdt/downloads/?project=3Dxsd">htt=
p://www.eclipse.org/modeling/mdt/downloads/?project=3Dxsd</A><BR></BLOCKQ=
UOTE>Be=20
sure to get a version that goes with your Eclipse version, i.e., 2.3.x =
goes=20
with Eclipe 3.3.x, and 2.4 goes with Eclipse 3.4. (You'd think =
that XSD=20
to Ecore conversion would be particularly useful in the EE package; go =
figure.)<BR><BR><BR>Karin Schellner wrote:=20
<BLOCKQUOTE cite=3Dmid:fmqkf6$pdn$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">I have installed the "Eclipse IDE for Java =
EE Developers" which includes all=20
about=20
dependencies ...
thanks,
karin.
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> schrieb im =
Newsbeitrag=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fmqboc$eur$1@build.eclipse.org">news:fmqboc$eur$1@build.ecli=
pse.org</A>...
Karin,
<workspace>/.metadata/.log which is what the Error log views). =
Then=20
Then=20
about=20
why=20
it's disabled...
org.eclipse.xsd
thanks,
karin
Newsbeitrag
href=3D"news:fmq3j5$ihc$2@build.eclipse.org">news:fmq3j5$ihc$2@build.ecli=
pse.org</A>...
Karin,
"Help->About Eclipse SDK->Plug-in Details..." are the =
org.eclipse.xsd
plugins there?
thanks,
karin.
=20
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000A_01C85C1A.DA55A490--
Current Time: Tue Apr 23 11:26:39 GMT 2024
Powered by FUDForum. Page generated in 0.03871 seconds
