Re: XSDEcoreBuilder and ePackage.name [message #415958 is a reply to message #415955] |
Sun, 13 January 2008 12:44 |
Ed Merks Messages: 33140 Registered: July 2009 |
--------------030206030209060007080302
Martin,
It's always kind of bothered me this whole issue of names for root
packages. Of course we have a constraint that the name of an
ENamedElement must be well formed Java identifier and hence can't
contain a ".". But that means to specify a fully qualified package
name for generation purposes we either have to create a whole set of
parent EPackage for the sole purpose of specifying the qualifies. I.e.,
the Ecore package's name is "ecore" but we want to generate to
org.eclipse.emf.ecore. To achieve that, we use the GenPackage's Base
Package property. But of course this approach makes the information
about qualification not available to the EPackage itself. And even if
you did specify a bunch of parent EPackage's EMF wouldn't generate them
if they contain no classifiers, i.e., an EPackage containing only other
EPackages but no EClassifiers will not actually be generated:142856
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=142856>
So what you're seeing in the XSDEcoreBuilder is kind of a
less-than-optimal solution where we populate the EPackage with the fully
qualified name (which you can explicitly set with an ecore:package
annotation) and then later when building the GenModel, we split that
name up and use it to populate the GenPackage's Base Package property.
Note that we did it this way because we don't want the XSD model to
depend on the GenModel and generally don't want the XSDEcoreBuilder,
which is used even for dynamic models, to depend on the GenModel, which
is more of a development time artifact.
So you can use ecore:package to shorten the name or you could specialize
the getEPackage method to shorten the name automatically. I've given
quite a bit of though to allowing the name of a package to contain a "."
or to introduce a qualifier attribute to EPackage itself, but all such
things are potentially disruptive to clients...
Martin Taal wrote:
> I have a question about how the XSDEcoreBuilder sets the
> ePackage.name. My experience is that if there is a targetNameSpace
> that the name of the EPackage is set to the java qualified package
> name. When I look in the code (XSDEcoreBuilder.getEPackage) it indeed
> seems to work like this.
> However when I do a new EMF model in Eclipse (when rightclicking on an
> xsd) I get a nicer epackage name. So there seems to be different
> behavior.
> Here is the top part of the xsd I am using:
> <schema
> targetNamespace="http://www.elver.org/test/models/accounting"
> xmlns="http://www.w3.org/2001/XMLSchema"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
> xmlns:this="http://www.elver.org/test/models/accounting"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> ecore:name="accounting" ecore:nsPrefix="acc">
> I would like the name accounting but the XSDEcoreBuilder gives me:
> org.elver.test.models.accounting.
> I have tried to change the behavior by adding ecore:name but the
> ecore:name attribute is not used by XSDEcoreBuilder for an ePackage.
> Is there something which I am doing wrong? Or should I use another
> xsdtoecore builder (the one used by the new emf model wizard)?
> Thanks!
<html>
<head>
</head>
Martin,<br>
<br>
I.e., the Ecore package's name is "ecore" but we want to generate to
EPackages but no EClassifiers will not actually be generated:<a
name="b142856"
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=142856">142856</a><br>
<br>
fully qualified name (which you can explicitly set with an
ecore:package annotation) and then later when building the GenModel, we
split that name up and use it to populate the GenPackage's Base Package
property. Note that we did it this way because we don't want the XSD
model to depend on the GenModel and generally don't want the
XSDEcoreBuilder, which is used even for dynamic models, to depend on
the GenModel, which is more of a development time artifact.<br>
<br>
specialize the getEPackage method to shorten the name automatically.
I've given quite a bit of though to allowing the name of a package to
contain a "." or to introduce a qualifier attribute to EPackage itself,
but all such things are potentially disruptive to clients...<br>
<br>
<br>
Martin Taal wrote:
<blockquote cite="mid:fmc6s3$3pq$1@build.eclipse.org" type="cite">Hi,
<br>
I have a question about how the XSDEcoreBuilder sets the ePackage.name.
My experience is that if there is a targetNameSpace that the name of
the EPackage is set to the java qualified package name. When I look in
the code (XSDEcoreBuilder.getEPackage) it indeed seems to work like
this.
<br>
<br>
behavior.
<br>
<br>
<br>
<schema
targetNamespace=<a class="moz-txt-link-rfc2396E" href="http://www.elver.org/test/models/accounting">"http://www.elver.org/test/models/accounting"</a>
<br>
xmlns=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>
<br>
xmlns:ecore=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/emf/2002/Ecore"</a>
<br>
xmlns:this=<a class="moz-txt-link-rfc2396E" href="http://www.elver.org/test/models/accounting">"http://www.elver.org/test/models/accounting"</a>
<br>
xmlns:xsd=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>
<br>
ecore:name="accounting " ecore:nsPrefix="acc">
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thanks!
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------030206030209060007080302--
Ed Merks
FUDForum. Page generated in 0.02928 seconds
