Re: How to load an model instance from its xmi file? [message #415943 is a reply to message #415942] |
Fri, 11 January 2008 17:56 |
Hi, Michael,
In the *.genmodel editor for your model, select the root (GenModel) node and
then invoke the "Generate Tests" action on the context menu. You will then
find a new project in your workspace with the same name as your model
plug-in, appended by ".tests"
HTH,
Christian
Michael wrote:
> Thanks for your help. But I have no idea of what the *.texts
> project
> is, where it is ,and how I can generate it.
> Thanks.
> Michael.
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:fm88sr$no7$1@build.eclipse.org...
>> Michael,
>> Yes. Generate the *.tests project and have a look at the generated
>> XyzExample.java. It's a stand alone command line utility for reading the
>> resource corresponding to the arguments passed to main.
>> Michael wrote:
>>> Hi,
>>> I have serilized a model instance into an xmi file in a default
>>> format. Now I want to load it to an in-memory object in a standalone
>>> java program. How can I do it?
>>> Thanks.
>>> Michael.
FUDForum. Page generated in 0.03510 seconds
