Home » Modeling » EMF » EMF Change plugin
EMF Change plugin [message #415713] Wed, 02 January 2008 20:59 Go to next message
Originally posted by: arazavi.swen.uwaterloo.ca
Hi All,
As part of my PhD project, I am considering creating a framework for
representing model changes. I would like it to be an underlying model for
model refactoring and update propagation across heterogenous emf models. I
came across org.eclipse.emf.change package in the EMF API. I am curious to
know about the purpouse of this package. Although this sounds like a good
place to start from, not all the classes are quite compatible with what I
have envisioned of a meta model for representing such changes. I was
thinking that there should be a closer relationship to the actual Ecore
metamodel (eg. having EStructuralFeatureChange, EReferenceChange etc. ). I
appreciate if someone sheds some light on this.
Thanks and Happy New year
Ali
Re: EMF Change plugin [message #415720 is a reply to message #415713] Thu, 03 January 2008 11:57 Go to previous messageGo to next message
Ali,
Comments below.
Ali Razavi wrote:
> Hi All,
Also have a look at the model used by the EMFT's compare component.
There they analyze difference between models rather than simply monitor
changes, which is a much harder problem since you have to establish
correspondence between objects in two separate instances.
Yes, I could imagine a change model being used as a script. After all,
it includes apply methods for applying the described changes to the
instance.
> I
The ChangeRecorder is designed to monitor all notifications thereby
knowing what's change; it keeps track of the old value the first time
there is a change to a particular feature. This information can be used
to build a ChangeDescription that represents as a model all the changes
made to the instance. Methods like apply/applyAndReverse can be used to
undo and redo those changes, which makes it useful for implementing
ChangeCommand's undo/redo support.
There's an awful lot of stuff that's common between EAttribute and
EReference so it seemed simpler to just have a single FeatureChange
class that serves for both. So things like getDataValue and
getReferenceValue are persistent features to store either the
EAttribute's value or the EReference's value and getValue returns either
one of the two. A similar thing could have been accomplished with a
common base class and two derived classes, but in that case, the
serialization would include an xsi:type and so is a bit more complex.
You're welcome and you too. I'd be happy to hear more about your work.
Perhaps it would make an interesting EMFT component. That way you could
do your work in the open with a community that's likely interested in
the results. I know talking to folks at Eclipse Summit Europe that
there are other researchers interested in scripted refactoring...
> Ali
Ed Merks
Re: EMF Change plugin [message #415723 is a reply to message #415720] Thu, 03 January 2008 13:50 Go to previous messageGo to next message
Hi, Ed, Ali,
One thing to be aware of in using change-recording and ChangeDescriptions to
track, undo, and script changes is its interaction with models that
implement internal side-effects. It can happen that a model implementation
internally maintains consistency in various ways, and that the mechanisms
it employs depend on the order in which changes are performed. Because the
ChangeDescription retains a delta between two model states, rather than a
list of the individual change operations, applying it to a model with
side-effects may result in erroneous behaviour as changes are applied in a
different order than those that were originally recorded.
I have seen this, for example, in using the change-recorder on UML models.
The MDT UML2 implementation of the UML metamodel has internal side-effects
such as
- maintaining consistency of superset-subset features
- applying required stereotypes on containment changes
- unapplying inapplicable stereotypes on containment changes
that are sensitive to the order in which changes are performed in order to
correctly replay changes observed previously using a ChangeRecorder. These
side-effects can also be generated into user APIs described by UML models
via UML2's codegen extensions.
This isn't to criticize the change recorder's set of assumptions about the
model's behaviour or UML2's decisions to implement side-effects. Just a
note to highlight potential issues. I imagine that the EMFT Compare
component's merging function would similarly need to be aware of a specific
model's side-effects.
Christian
Ed Merks wrote:
> Ali,
> Comments below.
> Ali Razavi wrote:
>> Hi All,
> instance.
>> I
>> to know about the purpouse of this package.
>> I appreciate if someone sheds some light on this.
>> Ali
Re: EMF Change plugin [message #415724 is a reply to message #415723] Thu, 03 January 2008 14:29 Go to previous messageGo to next message
--------------010708070502040006030008
Christian,
In the case of compare, it's impossible to know the order of the
changes. All you'd know is before and after states and not the path for
how you got there. It's of course best to avoid as much as possible
having the order in which things are done affect the correctness of the
behavior...
Christian W. Damus wrote:
> Hi, Ed, Ali,
> such as
> Cheers,
> Christian
> Ed Merks wrote:
>> Ali,
>> Comments below.
>> Ali Razavi wrote:
>>> Hi All,
>> instance.
>>> I
>>> Ali
<html>
<head>
</head>
Christian,<br>
<br>
changes.&nbsp; All you'd know is before and after states and not the path
for how you got there.&nbsp; It's of course best to avoid as much as
possible having the order in which things are done affect the
correctness of the behavior...<br>
<br>
<br>
<blockquote cite="mid:flip7p$apv$1@build.eclipse.org" type="cite">
<pre wrap="">Hi, Ed, Ali,
such as
Christian
Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Ali,
Comments below.
Ali Razavi wrote:
</pre>
<pre wrap="">Hi All,
</pre>
</blockquote>
<pre wrap="">Also have a look at the model used by the EMFT's compare component.
</pre>
<pre wrap="">I would like it to be an underlying model for
</pre>
</blockquote>
<pre wrap="">Yes, I could imagine a change model being used as a script. After all,
instance.
</pre>
<pre wrap=""> I
</pre>
</blockquote>
<pre wrap="">The ChangeRecorder is designed to monitor all notifications thereby
</pre>
<pre wrap=""> Although this sounds like a good
</pre>
</blockquote>
<pre wrap="">There's an awful lot of stuff that's common between EAttribute and
</pre>
<pre wrap="">Thanks and Happy New year
</pre>
</blockquote>
<pre wrap="">You're welcome and you too. I'd be happy to hear more about your work.
</pre>
<pre wrap="">Ali
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------010708070502040006030008--
Ed Merks
Re: EMF Change plugin [message #415725 is a reply to message #415724] Thu, 03 January 2008 15:16 Go to previous messageGo to next message
Hi, Ed,
Yes, what I meant w.r.t. compare is that the order in which changes are
applied by a merge may be significant, depending on the model
implementation.
I agree that dependencies on the ordering of changes are best avoided, but
clients of a model API don't have that choice. When working with UML2, at
least, these side-effects must to be taken into consideration. That may
mean that any system that propagates changes from one instance of a model
to another (Compare, CDO, etc.) may need special knowledge of certain
models (perhaps plugged in).
Christian
Ed Merks wrote:
> Christian,
> behavior...
>> Hi, Ed, Ali,
>> to track, undo, and script changes is its interaction with models that
>> implementation internally maintains consistency in various ways, and that
>> the mechanisms
>> the ChangeDescription retains a delta between two model states, rather
>> than a list of the individual change operations, applying it to a model
>> with side-effects may result in erroneous behaviour as changes are
>> applied in a different order than those that were originally recorded.
>> models. The MDT UML2 implementation of the UML metamodel has internal
>> side-effects such as
>> to
>> These side-effects can also be generated into user APIs described by UML
>> models via UML2's codegen extensions.
>> the
>> specific model's side-effects.
>> Cheers,
>> Christian
-----8<-----
Re: EMF Change plugin [message #415836 is a reply to message #415725] Wed, 09 January 2008 10:20 Go to previous message
Cedric Brun is currently offline Cedric BrunFriend
Hi Christain and Ed,
I think you're right about the specific merging, we can't, at the model
level, know if values should be set in a specific order that's why we
designed possible extension in order to provide specific merging.
In EMF Compare we use the Diff model which defined specific types for
EReference or EAttribute changes, as Ed said it has a lot in common but the
model has been proven to be quite easier to use in model to text or model
to model transformations if we had different types sharing a common super
type.
Cédric
> Hi, Ed,
> implementation.
> Cheers,
> Christian
> Ed Merks wrote:
>> Christian,
>> behavior...
>>> Hi, Ed, Ali,
>>> ChangeDescriptions to track, undo, and script changes is its interaction
>>> with models that
>>> that the mechanisms
>>> to
>>> the
>>> Cheers,
>>> Christian
> -----8<-----
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Previous Topic:newbie qn: multithreaded event notification
Next Topic:calling genmodel dynamic templates stored into plugins
Current Time: Tue Apr 16 22:53:15 GMT 2024
Powered by FUDForum. Page generated in 5.86976 seconds
