Home » Modeling » EMF » Two editors sharing the model and or edit plugins
Re: Two editors sharing the model and or edit plugins [message #415646 is a reply to message #415642] |
Sun, 23 December 2007 20:00 |
Ed Merks Messages: 33140 Registered: July 2009 |
--------------090600030802070004040404
Philipp,
Comments below.
Philipp W. Kutter wrote:
> Hi.
> I'd like to generate various editors for the same domain model.
How would they differ?
> They should be able to share the generated model plugin, and maybe as
> well to share the generated edit plugin.
It seems likely they should share pretty much everything. I.e., it
might be best to derive them from a common generated base...
> In principle I can achieve this with a genmodel per editor. If the
> options for the model sections are the same, they will generate the same
> code, and I only need to keep this sections in synch, ...
I don't understand why you'd want copies of the code...
> BUT this would only work if I could define the plugin-ids for edit and
> editor plugins on my own. This would need
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=163597
> to be implemented.
> Any chance to get this implemented fast?
I just did 210405
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=210405>. But I don't
think you're paying me enough. :-P Donate to Eclipse
<http://www.eclipse.org/donate/index.php>
> Even cooler would of course be, if two .genmodel files could share
> the model and/or edit sections. This would be possible by simply adding
> a reference (in addition to the exisiting containment) to these sections.
It's not entirely clear the value of multiple generated editors since so
few options affect their generation.
> Or does anyone have different ideas? Since the generator does not
> change the plugin id's after generation, I could change them by hand.
It seems best to have a common generated base...
> Best, Philipp
<html>
<head>
</head>
Philipp,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:fkma8q$e3n$1@build.eclipse.org" type="cite">Hi.
<br>
<br>
<br>
</blockquote>
How would they differ?<br>
<blockquote cite="mid:fkma8q$e3n$1@build.eclipse.org" type="cite"><br>
<br>
<br>
</blockquote>
might be best to derive them from a common generated base...<br>
<br>
same
<br>
<br>
</blockquote>
I don't understand why you'd want copies of the code...<br>
<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=163597">https://bugs.eclipse.org/bugs/show_bug.cgi?id=163597</a>
<br>
to be implemented.
<br>
<br>
<br>
</blockquote>
I just did <a name="b210405"
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=210405">210405</a>.
But I don't think you're paying me enough. :-P <a
href="http://www.eclipse.org/donate/index.php">Donate to Eclipse</a>
<br>
<br>
sections.
<br>
</blockquote>
so few options affect their generation.<br>
<br>
<br>
</blockquote>
It seems best to have a common generated base...<br>
Best, Philipp
<br>
</blockquote>
<br>
</body>
</html>
--------------090600030802070004040404--
Ed Merks
Re: Two editors sharing the model and or edit plugins [message #415656 is a reply to message #415646] |
Wed, 26 December 2007 10:04 |
Philipp Kutter Messages: 306 Registered: July 2009 |
Hi, Ed.
Most of the time, there will be two kinds of editors: one for the
technical user, that uses the generated editors as a support in
high level debugging while fixing operational problems, and testing
new developments. For this one, I will not do any hand coding.
The second one is for the end user: in this one, a lot of tuning is
done, properties are not shown, labels are made more readable,
e.t.c.
In the current case however, there are three distinct user groups.
Each of them is only allowed to see some part of the model, and to edit
some other parts of the model. Up to now we generate all from the
models, and I'd like to continue doing this.
I agree, as much as possible. But if I can choose between sharing of
..edit code and doing things on the code level, and having just two
different .genmodel files, I think having just two different .genmodels
and some duplicate generated code would be better.
>> to be implemented.
> I just did 210405
I'd love to be able to generate technical review work for you. We
however move away from technical topics to pure business modeling.
All I can do there is find budget to invest my own and my developers
time to contribute to the newsgroup and to contribute code.
And to communicate my strange ideas what EMF should be able to do..
All the best from Switzerland,
Philipp
>> Best, Philipp
Re: Two editors sharing the model and or edit plugins [message #415658 is a reply to message #415656] |
Wed, 26 December 2007 11:38 |
Philipp,
Comments below.
> Hi, Ed.
> e.t.c.
I still get the sense that a single dynamically configurable editor, a
ones derived from a common base, would be easier to maintain....
>>> as well to share the generated edit plugin.
I wonder why though, but hey, that's none of my business.
>>> same
>>> and editor plugins on my own. This would need
>>> to be implemented.
>> I just did 210405
Well, the editor plugin ID thing is done, so duplicating the GenModel
and using it to generate duplicate editors is a bit easier now. I even
made it possible to specify additional plugin dependencies for the
editor (and other projects) via the GenModel...
> Philipp
>>> sections.
>>> Best, Philipp
Ed Merks
Re: Two editors sharing the model and or edit plugins [message #415660 is a reply to message #415658] |
Wed, 26 December 2007 13:39 |
Hi, Ed.
Thanks a lot for the new features! Great XMas present.
Because we do not need to touch the code level. We want to work with
teams where only one of 5 persons has Java coding capabilities, the
others do plain EMF+OCL
Thus, its about having everybody productive. For you, and maybe me,
adapting the code may be easier, but not for our teams.
In addition I can much easier find a programmer who helps fine tuning
a generated .edit project, then having a programmer that keeps custom
made templates, doing the reuse of code. The first resouce is cheaper,
and easier to replace.
Great. We will experiment with this and test it.
Best, Philipp
>> Philipp
>>>> sections.
>>>> Best, Philipp
Current Time: Thu Apr 25 12:29:37 GMT 2024
Powered by FUDForum. Page generated in 0.03174 seconds
