Home » Modeling » EMF » ECore-XSD roundtrip tested on Birt Design.xsd: questions on root element
ECore-XSD roundtrip tested on Birt Design.xsd: questions on root element [message #415634] |
Sat, 22 December 2007 21:20 |
Philipp Kutter Messages: 306 Registered: July 2009 |
--------------010605020704090404070808
Hi.
I am working on Birt/EMF integration, and I try to get the
ECore/XSD roundtrip working for this schema (see attachment)The
((design.xsd is located in the BIRT source code in the
org.eclipse.birt.report.model project in the
src\org\eclipse\birt\report\model\parser\design.xsd file. ))
I create an EMF genmodel from the schema, and then I reexport it to XSD,
and try to get structurally the same. I intend to post problems here,
until they are all resolved or covered by feature/bugs ;-)
Here the first: (ORIGINAL is what Birt uses, ROUNDTRIP is the outcome
after we went through EMF roundtrip):
Root element
ORIGINAL
<xs:schema
targetNamespace="http://www.eclipse.org/birt/2005/design"
xmlns="http://www.eclipse.org/birt/2005/design"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
elementFormDefault="qualified"
attributeFormDefault="unqualified">
ROUNDTRIP
<xsd:schema
xmlns:design="http://www.eclipse.org/birt/2005/design"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
ecore:nsPrefix="design"
ecore:package="com.jaree.birt.design">
Here my questions:
1) how can I achieve, that the original definition:
is generated rather than
2)Why are the options
not in the generated schema?
3) Is there a way to avoid the generation of the ecore options and
namespace? I mean they where not needed at the beginning, so why having
them here?
It is very unlikely that a huge project like Birt can move their
code to EMF, but if the ECore-XSD roundtrip works properly, we do not
need to care. As well this is the entry into the MS world. I'd like
to repeat this experiment with the openoffice schema, and later
with some MS schemas.
Best, Philipp
Content-Type: text/xml;
name="design.xsd"
Content-Disposition: inline;
filename="design.xsd"
<!-- edited with XML Spy v4.3 U (http://www.xmlspy.com) by LEGO (LEGO) -->
<xs:schema targetNamespace="http://www.eclipse.org/birt/2005/design" xmlns="http://www.eclipse.org/birt/2005/design" xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:element name="report">
<xs:annotation>
<xs:documentation>A BIRT report design.</xs:documentation>
</xs:annotation>
<xs:complexType>
<xs:complexContent>
<xs:extension base="ModuleType">
<xs:sequence>
<xs:element name="styles" type="StylesType" minOccurs="0"/>
<xs:element name="body">
<xs:annotation>
<xs:documentation>Report content. Content is implied to fill the width of the page.</xs:documentation>
</xs:annotation>
<xs:complexType>
<xs:choice maxOccurs="unbounded">
<xs:element name="chart" type="ChartItemType"/>
<xs:element name="data" type="DataItemType"/>
<xs:element name="extended-item" type="ExtendedItemType"/>
<xs:element name="free-form" type="FreeFormItemType"/>
<xs:element name="grid" type="GridItemType"/>
<xs:element name="image" type="ImageItemType"/>
<xs:element name="include" type="IncludeItemType"/>
<xs:element name="label" type="LabelItemType"/>
<xs:element name="list" type="ListItemType"/>
<xs:element name="matrix" type="MatrixItemType"/>
<xs:element name="multi-line-data" type="MultiLineDataItemType"/>
<xs:element name="table" type="TableItemType"/>
<xs:element name="text" type="TextItemType"/>
<xs:element name="toc">
<xs:annotation>
<xs:documentation>Section that displays the report table of contents.</xs:documentation>
</xs:annotation>
</xs:element>
</xs:choice>
</xs:complexType>
</xs:element>
<xs:element name="scratch-pad" type="ComponentsType" minOccurs="0">
<xs:annotation>
<xs:documentation>Temporary storage for report items removed from the report design. The Factory ignores these items.</xs:documentation>
</xs:annotation>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:element>
<xs:element name="library">
<xs:annotation>
<xs:documentation>Root tag for a library file.</xs:documentation>
</xs:annotation>
<xs:complexType>
<xs:complexContent>
<xs:sequence>
<xs:element name="themes" type="ThemesType" minOccurs="0"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:element>
<xs:complexType name="BrowserControlType">
<xs:complexContent>
<xs:extension base="ReportItemType"/>
</xs:complexType>
<xs:complexType name="CellType">
<xs:annotation>
<xs:documentation>A cell in a table or grid</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:extension base="DesignElement">
<xs:sequence>
<xs:choice minOccurs="0" maxOccurs="unbounded">
<xs:annotation>
<xs:documentation>If more than one content item appears, then they are stacked vertically within the cell.</xs:documentation>
</xs:annotation>
<xs:element name="browser-control" type="BrowserControlType"/>
<xs:element name="line" type="LineItemType"/>
</xs:choice>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="ChartItemType">
<xs:annotation>
<xs:documentation>Business chart</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="ColumnType">
<xs:complexContent>
<xs:attribute name="repeat" type="xs:int" use="optional" default="1"/>
<xs:attribute name="width" type="DimensionType" use="optional"/>
<xs:attribute name="decimal-offset" type="DimensionType" use="optional"/>
</xs:extension>
</xs:complexType>
<xs:complexType name="ComponentsType">
<xs:element name="rectangle" type="ReportItemType"/>
<xs:annotation>
</xs:annotation>
</xs:element>
</xs:choice>
</xs:complexType>
<xs:complexType name="CustomType">
<xs:annotation>
<xs:documentation>Custom XML</xs:documentation>
</xs:annotation>
<xs:sequence minOccurs="0" maxOccurs="unbounded">
<xs:any/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="DataItemType">
<xs:annotation>
<xs:documentation>A data item that displays a query, computed or other data value.</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="DataSetType">
<xs:complexContent>
<xs:extension base="ReportElementType"/>
</xs:complexType>
<xs:complexType name="DataSetSlotType">
<xs:choice>
<xs:element name="oda-data-set" type="ExtendedDataSetType">
<xs:annotation>
<xs:documentation>ODA extended data set</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="script-data-set" type="ScriptDataSetType">
<xs:annotation>
<xs:documentation>Custom data set defined though scripts.</xs:documentation>
</xs:annotation>
</xs:element>
</xs:choice>
</xs:complexType>
<xs:complexType name="DataSourceType">
<xs:annotation>
<xs:documentation>A connection to an external data source.</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="DataSourcesType">
<xs:annotation>
<xs:documentation>Note that only the Jdbc Connection is defined, and that is preliminary. This section is to be completed by the Data Engine team.</xs:documentation>
</xs:annotation>
<xs:element name="oda-data-source" type="ExtendedDataSourceType">
<xs:annotation>
<xs:documentation>ODA extended data source.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="script-data-source" type="ScriptDataSourceType">
<xs:annotation>
<xs:documentation>Custom data source defined though scripts.</xs:documentation>
</xs:annotation>
</xs:element>
</xs:choice>
</xs:complexType>
<xs:complexType name="DynamicListType">
<xs:attribute name="data-set-name" type="xs:string" use="required"/>
<xs:attribute name="value-column" type="xs:string" use="optional"/>
<xs:attribute name="label-column" type="xs:string" use="optional"/>
</xs:complexType>
<xs:complexType name="ExpressionType">
<xs:annotation>
<xs:documentation>Represents an BIRT expression</xs:documentation>
</xs:annotation>
<xs:simpleContent>
<xs:extension base="xs:string"/>
</xs:simpleContent>
</xs:complexType>
<xs:complexType name="ExtendedItemType">
<xs:annotation>
<xs:documentation>User-defined report item</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:extension base="ReportItemType">
<xs:attribute name="extensionName" type="xs:string" use="required">
<xs:annotation>
<xs:documentation>Name of the extension plugin that provides a design-time UI for building the item.</xs:documentation>
</xs:annotation>
</xs:attribute>
</xs:extension>
</xs:complexType>
<xs:complexType name="FilterParamType">
<xs:annotation>
<xs:documentation>Represents a query-by-example (QBE) condition. Formerly known as an ad-hoc parameter.</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:extension base="ParameterType">
<xs:attribute name="type" type="ParameterDataType" use="optional" default="string"/>
</xs:extension>
</xs:complexType>
<xs:complexType name="FreeFormItemType">
<xs:annotation>
<xs:documentation>Free-form layout container</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:sequence>
<xs:element name="report-items">
<xs:complexType>
</xs:choice>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="GridItemType">
<xs:annotation>
<xs:documentation>Tabular static layout</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:sequence>
<xs:element name="row" type="RowType" minOccurs="0" maxOccurs="unbounded"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="GroupType">
<xs:annotation>
<xs:documentation>Common definition of groups within a list or a table.</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:attribute name="name" type="xs:string" use="optional"/>
<xs:attribute name="interval" type="GroupingIntervalType" use="optional" default="none"/>
<xs:attribute name="interval-range" type="xs:float" use="optional" default="1"/>
<xs:attribute name="sort-direction" type="SortDirectionType" use="optional" default="asc">
<xs:annotation>
<xs:documentation>Sort direction applies only to the default sort. Ignored if a custom group sort is provided. Default sort is based on the group key expression.</xs:documentation>
</xs:annotation>
</xs:attribute>
</xs:extension>
</xs:complexType>
<xs:complexType name="ImageItemType">
<xs:annotation>
<xs:documentation>An image item.</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="IncludeItemType">
<xs:annotation>
<xs:documentation>Includes another design into this one</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:attribute name="report-name" type="xs:string" use="required"/>
</xs:extension>
</xs:complexType>
<xs:complexType name="LabelItemType">
<xs:annotation>
<xs:documentation>A label item that displays static text.</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="LineItemType">
<xs:annotation>
<xs:documentation>A horizontal or vertical line item.</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="ListBandType">
<xs:annotation>
<xs:documentation>A section within a list. Each section can contain any number of sections.</xs:documentation>
</xs:annotation>
</xs:choice>
</xs:complexType>
<xs:complexType name="ListGroupType">
<xs:annotation>
<xs:documentation>Grouping level within a free-form list</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:extension base="GroupType">
<xs:sequence>
<xs:element name="header" type="ListBandType" minOccurs="0"/>
<xs:element name="footer" type="ListBandType" minOccurs="0"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="ListItemType">
<xs:annotation>
<xs:documentation>A free-form data-driven listing</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:extension base="ListingType">
<xs:sequence>
<xs:element name="header" type="ListBandType" minOccurs="0">
<xs:annotation>
<xs:documentation>Header printed before the first row of data.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="group" minOccurs="0" maxOccurs="unbounded">
<xs:annotation>
<xs:documentation>Grouping levels for the list.</xs:documentation>
</xs:annotation>
<xs:complexType>
<xs:complexContent>
<xs:extension base="ListGroupType"/>
</xs:complexType>
</xs:element>
<xs:element name="detail" type="ListBandType" minOccurs="0">
<xs:annotation>
<xs:documentation>Band displayed for each query row.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="footer" type="ListBandType" minOccurs="0">
<xs:annotation>
<xs:documentation>Footer section printed after all rows. Zones can conditionally print if no rows were available.</xs:documentation>
</xs:annotation>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="ListParamType">
<xs:complexContent>
</xs:extension>
</xs:complexType>
<xs:complexType name="MasterPageType">
<xs:annotation>
<xs:documentation>Predefined page styles</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="ResourcesType">
<xs:annotation>
<xs:documentation>Local list of externalized messages</xs:documentation>
</xs:annotation>
<xs:element name="resource" type="ResourceType" minOccurs="0" maxOccurs="unbounded">
<xs:annotation>
<xs:documentation>A single externalized message.</xs:documentation>
</xs:annotation>
</xs:element>
</xs:sequence>
</xs:complexType>
<xs:complexType name="MatrixItemType">
<xs:annotation>
<xs:documentation>Cross-tab (matrix) layout</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="MultiLineDataItemType">
<xs:complexContent>
</xs:complexType>
<xs:complexType name="PageBandType">
<xs:choice>
</xs:choice>
</xs:complexType>
<xs:complexType name="PageContentType">
</xs:choice>
</xs:complexType>
<xs:complexType name="PageSequenceType">
<xs:complexContent>
</xs:complexType>
<xs:complexType name="PageSetupType">
<xs:annotation>
<xs:documentation>Holds pages and page sequences</xs:documentation>
</xs:annotation>
<xs:sequence>
<xs:element name="graphic-master-page">
<xs:annotation>
<xs:documentation>Description of the master page with margins, marginalia, header, footer, watermark, etc.</xs:documentation>
</xs:annotation>
<xs:complexType>
<xs:complexContent>
<xs:extension base="MasterPageType">
<xs:sequence>
<xs:element name="contents" type="PageContentType" minOccurs="0"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:element>
<xs:element name="simple-master-page">
<xs:complexType>
<xs:complexContent>
<xs:sequence>
<xs:element name="page-header" type="PageBandType" minOccurs="0"/>
<xs:element name="page-footer" type="PageBandType" minOccurs="0"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:element>
</xs:choice>
</xs:sequence>
</xs:complexType>
<xs:complexType name="ParameterGroupType">
<xs:annotation>
<xs:documentation>Grouping of parameters</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:extension base="ReportElementType">
<xs:sequence minOccurs="0">
<xs:element name="parameters">
<xs:complexType>
<xs:element name="scalar-parameter" type="ScalarParamType"/>
<xs:element name="filter-parameter" type="FilterParamType"/>
<xs:element name="list-parameter" type="ListParamType"/>
<xs:element name="table-parameter" type="TableParamType"/>
</xs:choice>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="ParameterType">
<xs:annotation>
<xs:documentation>The base type for all parameters.</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="ParametersType">
<xs:annotation>
<xs:documentation>Collection of parameters or parameter groups</xs:documentation>
</xs:annotation>
<xs:element name="parameter-group" type="ParameterGroupType">
<xs:annotation>
<xs:documentation>Logical grouping of parameters.</xs:documentation>
</xs:annotation>
</xs:element>
</xs:choice>
</xs:complexType>
<xs:complexType name="ReportElementType">
<xs:annotation>
<xs:documentation>Base type for named report elements.</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:attribute name="name" type="xs:string" use="optional">
<xs:annotation>
<xs:documentation>An optional name for the component used when retrieving the component in code. Names must be unique within the design.</xs:documentation>
</xs:annotation>
</xs:attribute>
<xs:attribute name="extends" type="xs:string" use="optional">
<xs:annotation>
<xs:documentation>Name of a library component that this component extends. The library component must exist, and must be of the same type as this component.</xs:documentation>
</xs:annotation>
</xs:attribute>
</xs:extension>
</xs:complexType>
<xs:complexType name="ReportItemType">
<xs:complexContent>
</xs:complexType>
<xs:complexType name="RowType">
<xs:annotation>
<xs:documentation>One row in a table or grid.</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:sequence>
<xs:element name="cell" type="CellType" minOccurs="0" maxOccurs="unbounded"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="ScalarParamType">
<xs:annotation>
<xs:documentation>A parameter that holds a single, simple data value.</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:extension base="ParameterType"/>
</xs:complexType>
<xs:complexType name="Script">
<xs:annotation>
<xs:documentation>A JavaScript script. Cannot contain aggregates.</xs:documentation>
</xs:annotation>
<xs:simpleContent>
</xs:simpleContent>
</xs:complexType>
<xs:complexType name="StyleType">
<xs:annotation>
<xs:documentation>Attributes for a style</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="StylesType">
<xs:annotation>
<xs:documentation>List of shared styles</xs:documentation>
</xs:annotation>
<xs:element name="style">
<xs:complexType>
<xs:complexContent>
<xs:extension base="StyleType"/>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
<xs:complexType name="TableBandType">
<xs:annotation>
<xs:documentation>One band in a table (header, footer, etc.)</xs:documentation>
</xs:annotation>
<xs:sequence>
<xs:element name="row" minOccurs="0" maxOccurs="unbounded">
<xs:complexType>
<xs:complexContent>
<xs:extension base="RowType"/>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
<xs:complexType name="TableGroupType">
<xs:annotation>
<xs:documentation>A grouping level within a table</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:sequence>
<xs:element name="header" type="TableBandType" minOccurs="0"/>
<xs:element name="footer" type="TableBandType" minOccurs="0"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="TableItemType">
<xs:annotation>
<xs:documentation>A data-driven table: lists rows in tabular format</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:sequence>
<xs:element name="header" type="TableBandType" minOccurs="0">
<xs:annotation>
<xs:documentation>Header rows printed at the top of each page, and optionally at the top of each page if repeat-header is true.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="group" type="TableGroupType" minOccurs="0" maxOccurs="unbounded">
<xs:annotation>
<xs:documentation>Group level for the table.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="detail" type="TableBandType" minOccurs="0">
<xs:annotation>
<xs:documentation>Rows displayed for each query row.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="footer" type="TableBandType" minOccurs="0">
<xs:annotation>
<xs:documentation>Footer rows printed after all rows. Rows can conditionally print if no rows were available.</xs:documentation>
</xs:annotation>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="TableParamType">
<xs:complexContent>
</xs:complexType>
<xs:complexType name="TextItemType">
<xs:annotation>
<xs:documentation>A formatted, multi-line text item.</xs:documentation>
</xs:annotation>
<xs:complexContent>
</xs:complexType>
<xs:complexType name="ThemeType">
<xs:annotation>
<xs:documentation>An element that defined a group of styles.</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:sequence>
<xs:element name="Styles" type="StylesType"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="ThemesType">
<xs:annotation>
<xs:documentation>List of themes.</xs:documentation>
</xs:annotation>
<xs:element name="Theme" type="ThemeType"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="ValueType">
<xs:annotation>
<xs:documentation>An element that defines a constant value.</xs:documentation>
</xs:annotation>
<xs:sequence>
<xs:any>
<xs:annotation>
<xs:documentation>Allows for XML or Html inside the value.</xs:documentation>
</xs:annotation>
</xs:any>
</xs:sequence>
</xs:complexType>
<xs:complexType name="ListingType">
<xs:complexContent>
</xs:complexType>
<xs:simpleType name="AltSequenceStartType" final="restriction">
<xs:annotation>
<xs:documentation>Alt sequence page types.</xs:documentation>
</xs:annotation>
<xs:restriction base="xs:string">
<xs:enumeration value="left"/>
<xs:enumeration value="right"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="AnalysisType" final="restriction">
<xs:annotation>
<xs:documentation>Column attributes for e.Analysis</xs:documentation>
</xs:annotation>
<xs:enumeration value="auto"/>
<xs:enumeration value="dimension"/>
<xs:enumeration value="measure"/>
<xs:enumeration value="detail"/>
<xs:enumeration value="none"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="CellAlignment" final="restriction">
<xs:annotation>
<xs:documentation>How items are aligned with a tab stop.</xs:documentation>
</xs:annotation>
<xs:enumeration value="center"/>
<xs:enumeration value="decimal"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="ColorType" final="restriction">
<xs:annotation>
<xs:documentation>Color name or RGB value as defined in Html.</xs:documentation>
</xs:annotation>
<xs:restriction base="xs:string"/>
</xs:simpleType>
<xs:simpleType name="ColumnDataType" final="restriction">
<xs:enumeration value="any"/>
<xs:enumeration value="integer"/>
<xs:enumeration value="string"/>
<xs:enumeration value="date-time"/>
<xs:enumeration value="float"/>
<xs:enumeration value="structure"/>
<xs:enumeration value="table"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="ConjunctionType" final="restriction">
<xs:annotation>
<xs:documentation>The two types of condition parameter conjunctions: And and Or.</xs:documentation>
</xs:annotation>
<xs:enumeration value="and"/>
<xs:enumeration value="or"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="ControlType" final="restriction">
<xs:annotation>
<xs:documentation>The type of UI control to use for a parameter.</xs:documentation>
</xs:annotation>
<xs:enumeration value="text-box"/>
<xs:enumeration value="list-box"/>
<xs:enumeration value="radio-button"/>
<xs:enumeration value="check-box"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="DimensionType" final="restriction">
<xs:annotation>
<xs:documentation>A physical dimension represented as a float with option units.</xs:documentation>
</xs:annotation>
</xs:simpleType>
<xs:simpleType name="DistinctType" final="restriction">
<xs:annotation>
<xs:documentation>Options for suppressing duplicate values</xs:documentation>
</xs:annotation>
<xs:enumeration value="all">
<xs:annotation>
<xs:documentation>Show all values, including repeating values.</xs:documentation>
</xs:annotation>
</xs:enumeration>
<xs:enumeration value="repeat">
<xs:annotation>
<xs:documentation>Hide values that are the same as the previous row.</xs:documentation>
</xs:annotation>
</xs:enumeration>
<xs:enumeration value="repeatOnPage">
<xs:annotation>
<xs:documentation>Hide values the same as the previous row, except always show the first row on each new page.</xs:documentation>
</xs:annotation>
</xs:enumeration>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="DrilldownType" final="restriction">
<xs:annotation>
<xs:documentation>Drilldown options for groups and subreports.</xs:documentation>
</xs:annotation>
<xs:enumeration value="expanded"/>
<xs:enumeration value="hidden"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="DropType" final="restriction">
<xs:annotation>
<xs:documentation>Drop option for table rows. Controls how columns in one row overlap subsequent rows.</xs:documentation>
</xs:annotation>
<xs:enumeration value="all"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="ExportType" final="restriction">
<xs:annotation>
<xs:documentation>Query column export options.</xs:documentation>
</xs:annotation>
<xs:enumeration value="none">
<xs:annotation>
<xs:documentation>The column cannot be exported.</xs:documentation>
</xs:annotation>
</xs:enumeration>
<xs:enumeration value="if-realized">
<xs:annotation>
<xs:documentation>The column can be exported if the report design causes the column to be realized (written tot he report document file.)</xs:documentation>
</xs:annotation>
</xs:enumeration>
<xs:enumeration value="always">
<xs:annotation>
<xs:documentation>The column should always be realized in the report document even if it is not referenced in the design. The user can export the column.</xs:documentation>
</xs:annotation>
</xs:enumeration>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="FilterOperatorType" final="restriction">
<xs:annotation>
<xs:documentation>Operators supported for simple highlight and filter rules.</xs:documentation>
</xs:annotation>
<xs:enumeration value="lt"/>
<xs:enumeration value="le"/>
<xs:enumeration value="eq"/>
<xs:enumeration value="ne"/>
<xs:enumeration value="ge"/>
<xs:enumeration value="gt"/>
<xs:enumeration value="between"/>
<xs:enumeration value="not-between"/>
<xs:enumeration value="null"/>
<xs:enumeration value="not-null"/>
<xs:enumeration value="true"/>
<xs:enumeration value="false"/>
<xs:enumeration value="like"/>
<xs:enumeration value="top-n"/>
<xs:enumeration value="bottom-n"/>
<xs:enumeration value="top-percent"/>
<xs:enumeration value="bottom-percent"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="GroupingIntervalType" final="restriction">
<xs:annotation>
<xs:documentation>Type of grouping</xs:documentation>
</xs:annotation>
<xs:enumeration value="prefix"/>
<xs:enumeration value="year"/>
<xs:enumeration value="quarter"/>
<xs:enumeration value="month"/>
<xs:enumeration value="week"/>
<xs:enumeration value="day"/>
<xs:enumeration value="hour"/>
<xs:enumeration value="minute"/>
<xs:enumeration value="second"/>
<xs:enumeration value="interval"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="HighlightOperatorType" final="restriction">
<xs:annotation>
</xs:annotation>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="ImageSizeType" final="restriction">
<xs:annotation>
<xs:documentation>How to size an image within an image item.</xs:documentation>
</xs:annotation>
<xs:enumeration value="size-to-image"/>
<xs:enumeration value="scale-to-item"/>
<xs:enumeration value="clip">
<xs:annotation>
<xs:documentation>Clip the image to fit the available space. The bottom and/or right edges are clipped.</xs:documentation>
</xs:annotation>
</xs:enumeration>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="ImageType" final="restriction">
<xs:annotation>
<xs:documentation>MIME types for images</xs:documentation>
</xs:annotation>
<xs:enumeration value="image/jpeg"/>
<xs:enumeration value="image/bmp"/>
<xs:enumeration value="image/gif"/>
<xs:enumeration value="image/png"/>
<xs:enumeration value="image/x-png"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="JoinHintType" final="restriction">
<xs:annotation>
<xs:documentation>Hints for joins done within BIRT.</xs:documentation>
</xs:annotation>
<xs:enumeration value="merge"/>
<xs:enumeration value="leftLookup"/>
<xs:enumeration value="rightLookup"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="JoinOperatorType" final="restriction">
<xs:annotation>
<xs:documentation>Supported join operators.</xs:documentation>
</xs:annotation>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="JoinType" final="restriction">
<xs:annotation>
<xs:documentation>Type of join between two tables.</xs:documentation>
</xs:annotation>
<xs:enumeration value="inner"/>
<xs:enumeration value="leftOuter"/>
<xs:enumeration value="rightOuter"/>
<xs:enumeration value="fullOuter"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="LineOrientationType" final="restriction">
<xs:annotation>
<xs:documentation>Line item orientation.</xs:documentation>
</xs:annotation>
<xs:enumeration value="horizontal"/>
<xs:enumeration value="vertical"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="LineType" final="restriction">
<xs:annotation>
<xs:documentation>Attributes for a line segment</xs:documentation>
</xs:annotation>
<xs:enumeration value="solid"/>
<xs:enumeration value="dotted"/>
<xs:enumeration value="dashed"/>
<xs:enumeration value="double"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="OutputType" final="restriction">
<xs:annotation>
<xs:documentation>Output type names for hiding report items.</xs:documentation>
</xs:annotation>
<xs:enumeration value="viewer"/>
<xs:enumeration value="email"/>
<xs:enumeration value="print"/>
<xs:enumeration value="pdf"/>
<xs:enumeration value="rtf"/>
<xs:enumeration value="excel"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="PageBreakAfterType" final="restriction">
<xs:annotation>
<xs:documentation>Options for page break after.</xs:documentation>
</xs:annotation>
<xs:enumeration value="if-last"/>
<xs:enumeration value="always"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="PageBreakBeforeType" final="restriction">
<xs:annotation>
<xs:documentation>Options for page break before.</xs:documentation>
</xs:annotation>
<xs:enumeration value="if-first"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="PageOrientationType" final="restriction">
<xs:annotation>
<xs:documentation>Portrait or landscape</xs:documentation>
</xs:annotation>
<xs:enumeration value="portrait"/>
<xs:enumeration value="landscape"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="PageType" final="restriction">
<xs:annotation>
<xs:documentation>Known, predefined page sizes.</xs:documentation>
</xs:annotation>
<xs:enumeration value="us-letter">
<xs:annotation>
<xs:documentation>US letter sized paper: 8.5" x 11"</xs:documentation>
</xs:annotation>
</xs:enumeration>
<xs:en
Re: ECore-XSD roundtrip tested on Birt Design.xsd: questions on root element [message #415635 is a reply to message #415634] |
Sat, 22 December 2007 22:08 |
Ed Merks Messages: 33140 Registered: July 2009 |
Philipp,
I make no guarantee that XSD -> Ecore -> XSD is a round trip. I've
tried to ensure that Ecore -> XSD -> Ecore is a round trip and hence the
annotations to preserve details that aren't otherwise going to round
trip properly. More comments below.
Philipp W. Kutter wrote:
> Hi.
Since you already have a .xsd, it seems not particularly useful to try
to regenerate it...
> XSD, and try to get structurally the same. I intend to post problems
> here,
> Root element
> ORIGINAL
> <xs:schema
> ROUNDTRIP
> <xsd:schema
Things like the prefix used for the schema for schema namespace or
prefix for the target namespace are syntactic sugar that have no
semantic significance. Don't expect them to be preserved. Information
like the qualified namespace you used "com.jaree.birt.design" and the
nsPrefix won't be preserved without the annotations.
> Here my questions:
EMF won't generate this style for you unless you specialized the schema
builder to do that.
EMF only records the actual namespace on the elements and the attribute
and has no idea if they are the way they are because it's a local
element verses a global element or whether form="qualified" verses
elementFormDefault="qualified" is used. So this won't round trip
either. But the actual namespace for each element and attribute should
still be correct.
> having them here?
For roundtripping Ecore-> XSD -> Ecore they are needed. Again, you'd
need to specialize the build or post process the result to achieve this
goal.
> need to care.
I'm not sure why it matter. You have the schema, why is there a need to
generate it?
You'll find MS loves to fill schema with their own annotations. They
are perfectly acceptable annotations after all and all conforming
processors should tolerate them.
> Best, Philipp
Ed Merks
Re: ECore-XSD roundtrip tested on Birt Design.xsd: questions on root element [message #415636 is a reply to message #415635] |
Sun, 23 December 2007 01:39 |
Hi, Ed.
I understand. If XSD -> Ecore -> XSD round trip is not on your agenda,
I will not try to do it on my own...
Best, Philipp
Ed Merks wrote:
> Philipp,
>> Hi.
> to regenerate it...
>> here,
>> Root element
>> ORIGINAL
>> <xs:schema
>> ROUNDTRIP
>> <xsd:schema
>> Here my questions:
> builder to do that.
> still be correct.
>> having them here?
> goal.
>> need to care.
> generate it?
>> Best, Philipp
Current Time: Tue Apr 23 15:49:29 GMT 2024
Powered by FUDForum. Page generated in 0.04686 seconds
