Home » Modeling » EMF » Using the URI Converter
Re: Using the URI Converter [message #415543 is a reply to message #415533] |
Thu, 20 December 2007 13:17 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------040408040208000803020402
Vikram,
The thread from "Inhibiting EMF Lazy Loading For Manual Proxy URI
Update" a few notes up is dealing with the same issue. As explained
there, the reference to an object in a resource always uses
eObject.eResource().getURI() as the URI, so while a URI mapping can be
used to redirect where the input stream for the URI is located, it
doesn't affect the form in which references are saved. For that, the
resource's URI is always considered the logical URI and will be used
directly. So to rename a resource you must literally rename the
resource (or load it directly with the new renamed URI *before *using it
to resolve references to the old URI).
Vikram wrote:
> I am trying to load a resource and them update the references that have been
> renamed.
> Here are the steps:
> /// Code snippet
> ResourceSet rset = loadedResource.eResource().getResourceSet();
> URIConverter converter = rset.getURIConverter();
> converter.getURIMap().put(oldURI, newURI);
> EcoreUtil.resolveAll(rset);
> save(loadedResource);
> No error is being generated, however, when I open the loadedResource, it
> still has the old references.
> Vikram
<html>
<head>
</head>
Vikram,<br>
<br>
resource (or load it directly with the new renamed URI <b>before </b>using
it to resolve references to the old URI).<br>
<br>
<br>
Vikram wrote:
<blockquote cite="mid:fkcdaf$9ae$1@build.eclipse.org" type="cite">
<pre wrap="">Hi,
renamed.
Here are the steps:
/// Code snippet
Vikram
</pre>
</blockquote>
<br>
</body>
</html>
--------------040408040208000803020402--
Ed Merks
Re: Using the URI Converter [message #415576 is a reply to message #415543] |
Thu, 20 December 2007 17:19 |
Vikram Messages: 17 Registered: July 2009 |
Junior Member |
------=_NextPart_000_0036_01C84302.916B67F0
charset="iso-8859-1"
Ed,
Thanks for your help.=20
Vikram
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fkdq1i$nki$1@build.eclipse.org...
Vikram,
The thread from "Inhibiting EMF Lazy Loading For Manual Proxy URI =
Update" a few notes up is dealing with the same issue. As explained =
there, the reference to an object in a resource always uses =
eObject.eResource().getURI() as the URI, so while a URI mapping can be =
used to redirect where the input stream for the URI is located, it =
doesn't affect the form in which references are saved. For that, the =
resource's URI is always considered the logical URI and will be used =
directly. So to rename a resource you must literally rename the =
resource (or load it directly with the new renamed URI before using it =
Vikram wrote:=20
I am trying to load a resource and them update the references that have =
been=20
renamed.
Here are the steps:
/// Code snippet
ResourceSet rset =3D loadedResource.eResource().getResourceSet();
URIConverter converter =3D rset.getURIConverter();
No error is being generated, however, when I open the loadedResource, it =
Vikram
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3243" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your help. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Vikram</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fkdq1i$nki$1@build.eclipse.org">news:fkdq1i$nki$1@build.ecli=
pse.org</A>...</DIV>Vikram,<BR><BR>The=20
thread from "Inhibiting EMF Lazy Loading For Manual Proxy URI Update" =
a few=20
notes up is dealing with the same issue. As explained there, the =
eObject.eResource().getURI()=20
as the URI, so while a URI mapping can be used to redirect where the =
input=20
stream for the URI is located, it doesn't affect the form in which =
references=20
are saved. For that, the resource's URI is always considered the =
logical=20
URI and will be used directly. So to rename a resource you must=20
literally rename the resource (or load it directly with the new =
renamed URI=20
<B>before </B>using it to resolve references to the old=20
URI).<BR><BR><BR>Vikram wrote:=20
<BLOCKQUOTE cite=3Dmid:fkcdaf$9ae$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi,
been=20
renamed.
Here are the steps:
/// Code snippet
Vikram
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0036_01C84302.916B67F0--
Current Time: Thu Apr 25 16:07:36 GMT 2024
Powered by FUDForum. Page generated in 0.03231 seconds
